JPEG library build using RTEMS Graphics Toolkit.
Tue Oct 7 00:51:34 UTC 2014
On Mon, Oct 6, 2014 at 7:48 PM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Hello Thomas,
> On Monday 06 of October 2014 09:52:18 Thomas Kim wrote:
>> Dear Sir,
>> I am tring to build jpeg-8d library using do_it script RTEMS Graphics
>> Toolkit.
>> When I execute "./do_it -j", there is below error message.
>> ./do_it: 16: ./do_it: source: not found
>> VERSION FILE NOT CORRECT
> which version of RTEMS Graphics Toolkit are you using.
> I am reproducing with
> git clone git://git.rtems.org/rtems-graphics-toolkit.git
> cd rtems-graphics-toolkit
> git submodule update --init
> and I can confirm the problem with
> RTEMS_MAKEFILE_PATH=/opt/rtems4.11/arm-rtems4.11/lpc17xx_ea_ram/ ./do_it -j
> Reason is that ./do_it scrip is BASH specific and when /bin/sh
> points to DASH (Debian default) then there is a problem.
> I suggest next workaround for now
> diff --git a/do_it b/do_it
> index 6fe0f86..46aa50f 100755
> --- a/do_it
> +++ b/do_it
> @@ -1,4 +1,4 @@
> -#! /bin/sh
> +#! /bin/bash
>  #  Script to help build RTEMS Graphics Toolkit
> The particular problem with reading VERSIONS file should be corrected
> for DASH by
> @@ -13,7 +13,7 @@ if [ ! -r ${vfile} ] ; then
>    exit 1
>  fi
> -source ${vfile}
> +. ./${vfile}
>  if [ X${LIBJPEG} = X ] ; then
>    echo VERSION FILE NOT CORRECT
> @@ -208,7 +208,7 @@ echo "Generating RTEMS_SETTINGS file..."
>  make -f Makefile.settings clean all
>  check_status $? Could not generate RTEMS_SETTINGS
> -source ./RTEMS_SETTINGS
> +. ./RTEMS_SETTINGS
>  PREFIX=${BSPTOP}
> Which is correct for BASH as well.
> Gedare, please, commit it.
i made all three changes. Maybe it should just be sh and not bash?
Probably it does not make a big difference. I hope someday someone can
replace this repository with a set of configs for RSB, but that takes
some extra effort for building RTEMS libraries there.
> But even with this correction and /bin/sh = DASH there can be another
> problem. But at least ./do_it -j then works for me.
> ./do_it -A
> Has problem that there is missing greation of build directory for Nano-X
> and even when created manually,
>   mkdir -p build/microwin/src
> there is some problem with Microwindows GIT version checkout.
> We have workaround for that somewhere (Jan Dolezal?) but it should
> be corrected in Alexandru-Sever's GIT. I have asked for access
> to that but I am not sure if I have granted access already.
> The git://github.com/alex-sever-h/microwin.git git should be moved
> to rtems.org or RTEMS GitHub or integrated as branch to Microwindows
> mainline as long term solution.
Yes, we should fix that is a reverse dependency. I'd prefer to see it
upstream to Microwindows. RTEMS Project should not be carrying around
ports of 3rd party software unless absolutely necessary.
-Gedare
> Best wishes,
>              Pavel
