Bug in getcwd() also in 4.11 kernel
Wed Oct 15 00:21:08 UTC 2014
This looks like the same basic application setup and, if so, the stack size for the shell task was minimum. Almost certainly Yoo small.
On October 14, 2014 7:16:59 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
>On 15/10/2014 3:09 am, Hoefle Marco wrote:
>> Hello,
>> getcwd() seems also buggy on an external  FAT12 image. On 4.11 there
>is
>> no crash but this behavior:
>Why FAT12 ?
>Does FAT32 work ?
>> RAM disks registered
>> disk addr 1: 0x400c6fa0, size: 1000000
>> disk addr 2: 0x40074060, size: 262144
>> format /dev/rda done.
>> mount return: 0
>> mount return: 0
>>                 Starting 1 threads...
>> started thread 0: id: 0x0b010002, prio: 10
>>   starting shell
>> RTEMS SHELL (Ver.1.0-FRC):/dev/console. Oct 14 2014. 'help' to list
>> commands.
>> [/] # pwd
>> [/] # ls
>> dev   mram  sdram
>> [/] # cdhello dude, this is tick nr: 0
>> [/] # cd mram
>> hello dude, this is tick nr: 1
>> [/mram] # cd template
>> [/mram/template] # pwd
>> /mram/template
>> [/mram/template] # ls
>> logs  param
>> [/mram/template] #
>> [/mram/template] # cd logs
>> mount return: 0
>> mount return: 0
>>   starting shell
>> commands.
>> [/] # pwd
>> [/] # ls
>> dev   mram  sdram
>>   [/] # cd mram
>> /mram/template
>> logs  param
>> [/mram/template] #
>> [?] # pwd
>> I’ll be happy to forward the test case to an rtems developer.
>Please create a bug report for this and attach anything you think is
>important. The easier it is to reproduce the more chance someone will
>look into it.
>Thanks
>Chris
>> This behavior occurs only when mounting an external fat12 image
>> generated this way:
>> NAME = libfatfsimg
>> BUILDDIR = build
>> all: $(NAME).a
>> .PHONY: $(NAME).a
>> $(NAME).o:
>>        @echo [GEN FATFS] $@
>>        @dd if=/dev/zero of=$(NAME) bs=256 count=1024 > /dev/null
>>        /sbin/mkfs.vfat -F 12 -S 512 -s 1 -r 512 -f 1 -v $(NAME)
>>        mcopy -b/ -i $(NAME) content/* ::/
>>        @xxd -i $(NAME) > $(NAME).c
>>        @echo [CC]  $@
>>        @$(CC) -c $(CFLAGS) -o $@ $(NAME).c
>> $(NAME).a: $(NAME).o
>> @$(AR) rcs $@ $^
>> The object file is then linked against the rtems test application.
>> Marco
>> *From:*users [mailto:users-bounces at rtems.org] *On Behalf Of *Rohner
>Thomas
>> *Sent:* Donnerstag, 2. Oktober 2014 12:11
>> *To:* Joel Sherrill; rtems-users at rtems.org
>> *Subject:* RE: Bug in getcwd()
>> Hello,
>>>  We have a system with the following configuration.
>>> Platform:
>>> ·Chip GR712RC
>>>  ·Board: GR712 Development Board
>>>  ·Compiler RTEMS RCC (according to your websites version)
>>>  ·RTOS: RTEMS
>>>  ·Library: GR-RTEMS-DRIVER Version 1.2.1.0
>> I’m using FAT as filesystem. We have same phenomenon for FAT12 or
>FAT16!
>> Freundliche Grüsse / Kind regards,
>> image001
>> *Thomas Rohner*
>> Entwicklungsingenieur Software
>> nanoTRONIC GmbH
>> Werkstrasse 27, CH - 3250 Lyss
>> T: +41 32 384 69 30, F: +41 32 384 69 31
>> www.nanotronic.ch <http://www.nanotronic.ch/> |
>> thomas.rohner at nanotronic.ch <mailto:thomas.rohner at nanotronic.ch>
>> *From:*Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> *Sent:* Mittwoch, 1. Oktober 2014 20:11
>> *To:* Rohner Thomas; rtems-users at rtems.org
>> *Subject:* Re: Bug in getcwd()
>> On 10/1/2014 9:26 AM, Rohner Thomas wrote:
>>     Hello,
>>     maybe I found a bug in getcwd().
>>     We’re using RTEMS 4.0 with Gaisler-Aeroflex….
>>     With our libraries I get an erroneous string when directory-depth
>is
>>     about 4 folders from root!
>>     When I use this string to read directory it crahes!
>>     Is there a limitation of string-length?
>>     I get the same results for
>>     Char buffer[200];
>>     getcwd(buffer,sizeof(buffer));
>>     or
>>     char* ret = getcwd(NULL,0);
>> Is this with the IMFS? What BSP?
>> Can you put together a full test example so we can
>> see what is really happening?
>> There is a POSIX constant for PATH_MAX as I recall but
>> it is quite large.
>> image001
>> *Thomas Rohner*
>> nanoTRONIC GmbH
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com  <mailto:joel.sherrill at OARcorp.com>
>On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> users mailing list
>> users at rtems.org
