Off-topic: Why no compiler warning for this?
Peter Dufault
dufault at hda.com
Wed Oct 15 08:14:31 UTC 2014
This is really a gcc question, but with Joel working to wipe out warnings and not wanting to start a thread on another list I'm asking here. I stumbled on this sequence (obviously simplified) in my code. The "XXX" indicates a restriction I intended to remove but didn't, and it would have broken new code I've been writing. I noticed it before hitting the issue.
The ETPU_CHANNEL_BIT macro is appropriate for the MPC5554 eTPUA with channels 0 through 31. The macro is going to left-shift out of the unit32_t for the channels 32 through 63 in eTPUB (not sure why I bothered with the modulus, it's going to be totally broken for larger channel numbers). Code:
#include <inttypes.h>
/* XXX Need a way to specify which eTPU the channel is in.
* They happen to both be in A.
#define ETPU_CHANNEL_BIT(CHAN) (1 << ((CHAN) % 64))
extern void foo(int chan);
extern void bar(uint32_t bit);
void foo(int chan) {
uint32_t bit = ETPU_CHANNEL_BIT(chan);
bar(bit);
Here is the optimization level and the compiler warnings I had in effect. I even added -Wstrict-overflow=5 and -O4 hoping to get a warning without luck.
-O2
-Wall
-Wcast-qual
-Werror
-Wmissing-prototypes
-Wpointer-arith
Anyone else surprised? Am I missing something obvious? Any suggested additional warnings?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
