Bug in getcwd() also in 4.11 kernel
Rohner Thomas Thomas.Rohner at nanotronic.ch
Wed Oct 15 11:09:34 UTC 2014
During my tests with a filesystem < 12MB the FAT32 wasn't working.
Isn't it like this that the table for FAT32 is too large for only 12MB of memory.
Aer there other limitations?
Freundliche Grüsse / Kind regards,
Thomas Rohner
Entwicklungsingenieur Software
nanoTRONIC GmbH
Werkstrasse 27, CH - 3250 Lyss
T: +41 32 384 69 30, F: +41 32 384 69 31
www.nanotronic.ch | thomas.rohner at nanotronic.ch
-----Original Message-----
Sent: Mittwoch, 15. Oktober 2014 02:17
To: Hoefle Marco; Rohner Thomas; Joel Sherrill; rtems-users at rtems.org
Subject: Re: Bug in getcwd() also in 4.11 kernel
On 15/10/2014 3:09 am, Hoefle Marco wrote:
> Hello,
> getcwd() seems also buggy on an external  FAT12 image. On 4.11 there
> is no crash but this behavior:
Why FAT12 ?
Does FAT32 work ?
> RAM disks registered
> disk addr 1: 0x400c6fa0, size: 1000000
> disk addr 2: 0x40074060, size: 262144
> format /dev/rda done.
> mount return: 0
> mount return: 0
>                 Starting 1 threads...
> started thread 0: id: 0x0b010002, prio: 10
>   starting shell
> RTEMS SHELL (Ver.1.0-FRC):/dev/console. Oct 14 2014. 'help' to list
> commands.
> [/] # pwd
> [/] # ls
> dev   mram  sdram
> [/] # cdhello dude, this is tick nr: 0
> [/] # cd mram
> hello dude, this is tick nr: 1
> [/mram] # cd template
> [/mram/template] # pwd
> /mram/template
> [/mram/template] # ls
> logs  param
> [/mram/template] #
> [/mram/template] # cd logs
> mount return: 0
> mount return: 0
>   starting shell
> commands.
> [/] # pwd
> [/] # ls
> dev   mram  sdram
>   [/] # cd mram
> /mram/template
> logs  param
> [/mram/template] #
> [?] # pwd
> I'll be happy to forward the test case to an rtems developer.
Please create a bug report for this and attach anything you think is important. The easier it is to reproduce the more chance someone will look into it.
Thanks
> This behavior occurs only when mounting an external fat12 image
> generated this way:
> NAME = libfatfsimg
> BUILDDIR = build
> all: $(NAME).a
> .PHONY: $(NAME).a
> $(NAME).o:
>        @echo [GEN FATFS] $@
>        @dd if=/dev/zero of=$(NAME) bs=256 count=1024 > /dev/null
>        /sbin/mkfs.vfat -F 12 -S 512 -s 1 -r 512 -f 1 -v $(NAME)
>        mcopy -b/ -i $(NAME) content/* ::/
>        @xxd -i $(NAME) > $(NAME).c
>        @echo [CC]  $@
>        @$(CC) -c $(CFLAGS) -o $@ $(NAME).c
> $(NAME).a: $(NAME).o
> @$(AR) rcs $@ $^
> The object file is then linked against the rtems test application.
> Marco
> *From:*users [mailto:users-bounces at rtems.org] *On Behalf Of *Rohner
> Thomas
> *Sent:* Donnerstag, 2. Oktober 2014 12:11
> *To:* Joel Sherrill; rtems-users at rtems.org
> *Subject:* RE: Bug in getcwd()
> Hello,
>>  We have a system with the following configuration.
>> Platform:
>> ·Chip GR712RC
>>  ·Board: GR712 Development Board
>>  ·Compiler RTEMS RCC (according to your websites version)
>>  ·RTOS: RTEMS
>>  ·Library: GR-RTEMS-DRIVER Version 1.2.1.0
> I'm using FAT as filesystem. We have same phenomenon for FAT12 or FAT16!
> image001
> *Thomas Rohner*
> nanoTRONIC GmbH
> www.nanotronic.ch <http://www.nanotronic.ch/> |
> thomas.rohner at nanotronic.ch <mailto:thomas.rohner at nanotronic.ch>
> *From:*Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> *Sent:* Mittwoch, 1. Oktober 2014 20:11
> *To:* Rohner Thomas; rtems-users at rtems.org
> *Subject:* Re: Bug in getcwd()
> On 10/1/2014 9:26 AM, Rohner Thomas wrote:
>     Hello,
>     maybe I found a bug in getcwd().
>     We're using RTEMS 4.0 with Gaisler-Aeroflex....
>     With our libraries I get an erroneous string when directory-depth is
>     about 4 folders from root!
>     When I use this string to read directory it crahes!
>     Is there a limitation of string-length?
>     I get the same results for
>     Char buffer[200];
>     getcwd(buffer,sizeof(buffer));
>     or
>     char* ret = getcwd(NULL,0);
> Is this with the IMFS? What BSP?
> Can you put together a full test example so we can see what is really
> happening?
> There is a POSIX constant for PATH_MAX as I recall but it is quite
> large.
> image001
> *Thomas Rohner*
> nanoTRONIC GmbH
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com  <mailto:joel.sherrill at OARcorp.com>         On-Line Applications Research
> Support Available                (256) 722-9985
> users mailing list
> users at rtems.org
