Off-topic: Why no compiler warning for this?
Peter Dufault dufault at hda.com
Wed Oct 15 12:23:04 UTC 2014
BTW: This macro is more broken than I thought.  eTPUB channels are 64 through 95.
I suppose the reason there is no warning for the left shift that "obviously might overflow" is the same reason you don't get warnings about all multiplies - gcc isn't going to warn on all multiplies that might overflow.
On Oct 15, 2014, at 04:14 , Peter Dufault <dufault at hda.com> wrote:
> This is really a gcc question, but with Joel working to wipe out warnings and not wanting to start a thread on another list I'm asking here.  I stumbled on this sequence (obviously simplified) in my code.  The "XXX" indicates a restriction I intended to remove but didn't, and it would have broken new code I've been writing.  I noticed it before hitting the issue.
> The ETPU_CHANNEL_BIT macro is appropriate for the MPC5554 eTPUA with channels 0 through 31.  The macro is going to left-shift out of the unit32_t for the channels 32 through 63 in eTPUB (not sure why I bothered with the modulus, it's going to be totally broken for larger channel numbers).  Code:
> #include <inttypes.h>
> /* XXX Need a way to specify which eTPU the channel is in.
> *     They happen to both be in A.
> #define ETPU_CHANNEL_BIT(CHAN) (1 << ((CHAN) % 64))
> extern void foo(int chan);
> extern void bar(uint32_t bit);
> void foo(int chan) {
>    uint32_t bit = ETPU_CHANNEL_BIT(chan);
>    bar(bit);
> Here is the optimization level and the compiler warnings I had in effect.  I even added -Wstrict-overflow=5 and -O4 hoping to get a warning without luck.
> -O2
> -Wall
> -Wcast-qual
> -Werror
> -Wmissing-prototypes
> -Wpointer-arith
> Anyone else surprised?  Am I missing something obvious?  Any suggested additional warnings?
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> users mailing list
> users at rtems.org
Peter
Peter Dufault
