Nested structures in headers and C++ compatibility?
Peter Dufault
dufault at hda.com
Thu Oct 16 10:42:47 UTC 2014
In the MPC55XX headers there are typedefs that reference nested structures such as:
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
typedef struct {
uint32_t index : 10;
uint32_t count : 10;
uint32_t output : 1;
union SIU_PCR_tag pcr;
} mpc55xx_siu_pcr_config;
#ifdef __cplusplus
#endif
where SIU_PCR_tag is a nested structure:
struct SIU_tag {
union SIU_PCR_tag { /* Pad Configuration Registers */
and extern "C" brackets don't prevent C++ errors such as:
error: field 'pcr' has incomplete type
The only hack I have is to re-define the typedef to scope the type:
typedef struct {
#ifdef __cplusplus
union SIU_tag::SIU_PCR_tag pcr;
#else
#endif
although I suppose a preferable approach might be:
#ifdef __cplusplus
typedef SIU_tag::SIU_PCR_tag SIU_PCR_tag_type;
#else
typedef union SIU_PCR_tag SIU_PCR_tag_type;
#endif
typedef struct {
SIU_PCR_tag_type pcr;
Any thoughts? Any better way?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
