samples/fileio - ram disk testing failure in case of restoring disk image from NAND to SRAM.
Thomas Kim
thomas73.kim at gmail.com
Tue Oct 21 01:35:39 UTC 2014
Dear Sebastian,
NAND flash is only used for storing FAT32 disk image.
After this disk image of flash is copied on SRAM by bootloader, RTEMS DOS
file system is mounted for disk clone image on SRAM.
Best Regards,
Thomas
2014-10-20 21:07 GMT+09:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 20/10/14 11:07, Thomas Kim wrote:
>> NAND Flash 64MB area have MS-DOS FAT32 Disk image.
> FAT32 is unsuitable for NAND flash devises unless you use a flash
> translation layer.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20141021/2cf557d8/attachment.html>
