samples/fileio - ram disk testing failure in case of restoring disk image from NAND to SRAM.
Hoefle Marco
Marco.Hoefle at nanotronic.ch
Tue Oct 21 08:14:26 UTC 2014
Hello Thomas,
How do you create the FATFS image? I have also an issue with FAT image linked into the application.
In my case getcwd() is not working correctly after being deeper than 3 subfolders.
But the rest seems to work ok.
I filed this bug
https://www.rtems.org/bugzilla/show_bug.cgi?id=2190
with a test case.
For us only Fat12 or FAT16 work, FAT32 didn't work with the image generation process described in the bug report.
Best regards,
Marco
________________________________
From: users [mailto:users-bounces at rtems.org] On Behalf Of Thomas Kim
Sent: Dienstag, 21. Oktober 2014 03:36
To: Sebastian Huber
Cc: rtems-users at rtems.org
Subject: Re: samples/fileio - ram disk testing failure in case of restoring disk image from NAND to SRAM.
Dear Sebastian,
NAND flash is only used for storing FAT32 disk image.
After this disk image of flash is copied on SRAM by bootloader, RTEMS DOS file system is mounted for disk clone image on SRAM.
Best Regards,
Thomas
2014-10-20 21:07 GMT+09:00 Sebastian Huber <sebastian.huber at embedded-brains.de>:
On 20/10/14 11:07, Thomas Kim wrote:
NAND Flash 64MB area have MS-DOS FAT32 Disk image.
FAT32 is unsuitable for NAND flash devises unless you use a flash translation layer.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20141021/ac5edb8c/attachment.html>
