samples/fileio - ram disk testing failure in case of restoring disk image from NAND to SRAM.
Thomas Kim
thomas73.kim at gmail.com
Tue Oct 21 08:32:48 UTC 2014
Dear Marco,
I created FATFS disk image using OSFMount tool. you can download OSFMount
free version in below URL.
http://www.osforensics.com/tools/mount-disk-images.html
In my case, I created FAT16 image and FAT32 image for 64MB using raw image
type.
I did not test getcwd() directly. but, when I test in shell, there is no
problem using pwd, cd, ls.
but, I still have a problem for using file I/O command(cp, mv, rm, etc).
On referencing, there is not this problem in original fileio code(ram disk
area is allocated using malloc).
Best Regards,
Thomas.
2014-10-21 17:14 GMT+09:00 Hoefle Marco <Marco.Hoefle at nanotronic.ch>:
> Hello Thomas,
> How do you create the FATFS image? I have also an issue with FAT image
> linked into the application.
> In my case getcwd() is not working correctly after being deeper than 3
> subfolders.
> But the rest seems to work ok.
> I filed this bug
> https://www.rtems.org/bugzilla/show_bug.cgi?id=2190
> with a test case.
> For us only Fat12 or FAT16 work, FAT32 didn’t work with the image
> generation process described in the bug report.
> Best regards,
> Marco
> *From:* users [mailto:users-bounces at rtems.org] *On Behalf Of *Thomas Kim
> *Sent:* Dienstag, 21. Oktober 2014 03:36
> *To:* Sebastian Huber
> *Cc:* rtems-users at rtems.org
> *Subject:* Re: samples/fileio - ram disk testing failure in case of
> Dear Sebastian,
> NAND flash is only used for storing FAT32 disk image.
> After this disk image of flash is copied on SRAM by bootloader, RTEMS DOS
> file system is mounted for disk clone image on SRAM.
> Best Regards,
> Thomas
> 2014-10-20 21:07 GMT+09:00 Sebastian Huber <
> sebastian.huber at embedded-brains.de>:
> On 20/10/14 11:07, Thomas Kim wrote:
> NAND Flash 64MB area have MS-DOS FAT32 Disk image.
> FAT32 is unsuitable for NAND flash devises unless you use a flash
> translation layer.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20141021/0634b3b9/attachment-0001.html>
