RSB build process failure for Sparc
Thomas Kim
thomas73.kim at gmail.com
Fri Oct 24 10:19:50 UTC 2014
Dear Chris,
I attached this. I removed a half of message due to big size.
Best Regards.
2014-10-23 21:53 GMT+09:00 Chris Johns <chrisj at rtems.org>:
> On 23/10/2014 3:37 am, Thomas Kim wrote:
>> Dear Sir,
>> I am tring to upgrade gcc 4.8.2 to gcc 4.8.3 using RSB build procedure.
>> I tested build according to
>> http://www.rtems.org/wiki/index.php/RTEMS_Source_Builder .
>> At this time, there is a error as like below;
>> Please let me know how to resolve this.
> Can you please send me the error report the RSB generated called ..
> rsb-report-sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530
> 453b9f8443-1.txt
> Thanks
> Chris
> < Console message >
>> sudo ../source-builder/sb-set-builder --log=l-sparc.txt
>> --prefix=/opt/rtems-4.11 4.11/rtems-sparc
>> RTEMS Source Builder - Set Builder, v0.4.0
>> Build Set: 4.11/rtems-sparc
>> Build Set: 4.11/rtems-autotools.bset
>> Build Set: 4.11/rtems-autotools-internal.bset
>> config: tools/rtems-autoconf-2.69-1.cfg
>> package: autoconf-2.69-i686-linux-gnu-1
>> Creating source directory: sources
>> download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz ->
>> sources/autoconf-2.69.tar.gz
>> downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
>> building: autoconf-2.69-i686-linux-gnu-1
>> config: tools/rtems-automake-1.12.6-1.cfg
>> package: automake-1.12.6-i686-linux-gnu-1
>> download: ftp://ftp.gnu.org/gnu/automake/automake-1.12.6.tar.gz ->
>> sources/automake-1.12.6.tar.gz
>> downloading: sources/automake-1.12.6.tar.gz - 2.0MB of 2.0MB (100%)
>> building: automake-1.12.6-i686-linux-gnu-1
>> cleaning: autoconf-2.69-i686-linux-gnu-1
>> cleaning: automake-1.12.6-i686-linux-gnu-1
>> Build Set: Time 0:00:16.952695
>> Build Set: 4.11/rtems-autotools-base.bset
>> installing: autoconf-2.69-i686-linux-gnu-1 -> /home/junbeom/rtems-4.11
>> installing: automake-1.12.6-i686-linux-gnu-1 -> /home/junbeom/rtems-4.11
>> Build Set: Time 0:00:05.613289
>> Build Set: Time 0:00:22.566671
>> config: devel/expat-2.1.0-1.cfg
>> package: expat-2.1.0-i686-linux-gnu-1
>> download:
>> http://downloads.sourceforge.net/project/expat/expat/2.1.0/
>> expat-2.1.0.tar.gz
>> -> sources/expat-2.1.0.tar.gz
>> downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
>> building: expat-2.1.0-i686-linux-gnu-1
>> config: tools/rtems-binutils-2.24-1.cfg
>> package: sparc-rtems4.11-binutils-2.24-1
>> download: ftp://ftp.gnu.org/gnu/binutils/binutils-2.24.tar.bz2 ->
>> sources/binutils-2.24.tar.bz2
>> downloading: sources/binutils-2.24.tar.bz2 - 21.7MB of 21.7MB (100%)
>> building: sparc-rtems4.11-binutils-2.24-1
>> config: tools/rtems-gcc-4.8.3-newlib-git-1.cfg
>> package:
>> 453b9f8443-1
>> download: ftp://ftp.gnu.org/gnu/gcc/gcc-4.8.3/gcc-4.8.3.tar.bz2 ->
>> sources/gcc-4.8.3.tar.bz2
>> downloading: sources/gcc-4.8.3.tar.bz2 - 82.1MB of 82.1MB (100%)
>> Creating source directory: sources/git
>> git: clone: git://sourceware.org/git/newlib.git
>> <http://sourceware.org/git/newlib.git> -> sources/git/newlib.git
>> git: fetch: git://sourceware.org/git/newlib.git
>> git: reset: git://sourceware.org/git/newlib.git
>> git: checkout: git://sourceware.org/git/newlib.git
>> <http://sourceware.org/git/newlib.git> => master
>> ebbb290f6e15e71b140a911c0de530453b9f8443
>> download: http://www.mpfr.org/mpfr-3.0.1/mpfr-3.0.1.tar.bz2 ->
>> sources/mpfr-3.0.1.tar.bz2
>> downloading: sources/mpfr-3.0.1.tar.bz2 - 1.1MB of 1.1MB (100%)
>> download: http://www.multiprecision.org/mpc/download/mpc-0.8.2.tar.gz ->
>> sources/mpc-0.8.2.tar.gz
>> downloading: sources/mpc-0.8.2.tar.gz - 535.5kB of 535.5kB (100%)
>> download: ftp://ftp.gnu.org/gnu/gmp/gmp-5.0.5.tar.bz2 ->
>> sources/gmp-5.0.5.tar.bz2
>> downloading: sources/gmp-5.0.5.tar.bz2 - 2.0MB of 2.0MB (100%)
>> building:
>> 453b9f8443-1
>> error: building
>> 453b9f8443-1
>> Build FAILED
>> See error report:
>> ebbb290f6e15e71b140a911c0de530453b9f8443-1.txt
>> error: building
>> 453b9f8443-1
>> Build Set: Time 0:04:24.854524
>> Build FAILED
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20141024/65dc3ae3/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1
Command Line: ../source-builder/sb-set-builder --log=l-sparc.txt --prefix=/home/junbeom/rtems-4.11 4.11/rtems-sparc
Python: 2.7.3 (default, Feb 27 2014, 20:00:17) [GCC 4.6.3]
git://git.rtems.org/rtems-source-builder.git/origin/7c8c1d1deaac59010ef9c2068d8af02c99303a32
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/loop-unroll.c -o loop-unroll.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/loop-unswitch.c -o loop-unswitch.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lower-subreg.c -o lower-subreg.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lra.c -o lra.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lra-assigns.c -o lra-assigns.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lra-coalesce.c -o lra-coalesce.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lra-constraints.c -o lra-constraints.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lra-eliminations.c -o lra-eliminations.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lra-lives.c -o lra-lives.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lra-spills.c -o lra-spills.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-cgraph.c -o lto-cgraph.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-streamer.c -o lto-streamer.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-streamer-in.c -o lto-streamer-in.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-streamer-out.c -o lto-streamer-out.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-section-in.c -o lto-section-in.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-section-out.c -o lto-section-out.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-symtab.c -o lto-symtab.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-opts.c -o lto-opts.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/lto-compress.c -o lto-compress.o
../../gcc-4.8.3/gcc/lto-compress.c:28:18: fatal error: zlib.h: No such file or directory
compilation terminated.
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/mcf.c -o mcf.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/mode-switching.c -o mode-switching.o
/usr/bin/g++ -O2 -pipe -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/tmp/sb-junbeom/4.11/rtems-sparc/home/junbeom/rtems-4.11/include -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.8.3/gcc -I../../gcc-4.8.3/gcc/. -I../../gcc-4.8.3/gcc/../include -I../../gcc-4.8.3/gcc/../libcpp/include -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/gmp -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/./mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpfr -I/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/gcc-4.8.3/mpc/src -I../../gcc-4.8.3/gcc/../libdecnumber -I../../gcc-4.8.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.8.3/gcc/../libbacktrace ../../gcc-4.8.3/gcc/modulo-sched.c -o modulo-sched.o
make[2]: *** [lto-compress.o] Error 1
make[2]: *** Waiting for unfinished jobs....
rm gcc.pod
make[2]: Leaving directory `/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build/gcc'
make[1]: *** [all-gcc] Error 2
make[1]: Leaving directory `/home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex /home/junbeom/rsb_build/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-ebbb290f6e15e71b140a911c0de530453b9f8443-1/doit
