The error in building rtems source about stm32f4 bsp
ZhangZhenxing harbor0727 at gmail.com
Wed Oct 29 14:07:51 UTC 2014
Hi,
I got the rtems source builder by the git command("git clone git://git.rtems.org/rtems-source-builder.git") and builded rtems 4.11 toolschain by rtems source builder with the configure command("../rtems-4.10.99/configure --target=arm-rtems4.11 --enable-posix --enable-networking --enable-cxx --enable-rtemsbsp=stm32f4 --prefix=/opt/rtems-4.11/"). Then, when executing "sudo make all install" after "./configure", there is a error as follow. Why is it? How can I do for it? Thank you very much!
make[8]: Entering directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm/stm32f4'
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/bsp_specs ../../../../../.././stm32f4/lib/bsp_specs
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/tm27.h ../../../../../.././stm32f4/lib/include/tm27.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/bsp.h ../../../../../.././stm32f4/lib/include/bsp.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/coverhd.h ../../../../../.././stm32f4/lib/include/coverhd.h
/usr/bin/install -c -m 644 include/bspopts.h ../../../../../.././stm32f4/lib/include/bspopts.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/bootcard.h ../../../../../.././stm32f4/lib/include/bsp/bootcard.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/utility.h ../../../../../.././stm32f4/lib/include/bsp/utility.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-generic.h ../../../../../.././stm32f4/lib/include/bsp/irq-generic.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-info.h ../../../../../.././stm32f4/lib/include/bsp/irq-info.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/stackalloc.h ../../../../../.././stm32f4/lib/include/bsp/stackalloc.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/include/start.h ../../../../../.././stm32f4/lib/include/bsp/start.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/armv7m/include/armv7m-irq.h ../../../../../.././stm32f4/lib/include/bsp/armv7m-irq.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/irq.h ../../../../../.././stm32f4/lib/include/bsp/irq.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/usart.h ../../../../../.././stm32f4/lib/include/bsp/usart.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h ../../../../../.././stm32f4/lib/include/bsp/stm32f4.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_gpio.h ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_gpio.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_rcc.h ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_rcc.h
/usr/bin/install -c -m 644 ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_exti.h ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_exti.h
make[8]: *** No rule to make target `include/stm32f4xxxx_adc.h', needed by `../../../../../.././stm32f4/lib/include/bsp/stm32f4xxxx_adc.h'. Stop.
make[8]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm/stm32f4'
make[7]: *** [preinstall-recursive] Error 1
make[7]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm'
make[6]: *** [preinstall-recursive] Error 1
make[6]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp'
make[5]: *** [preinstall-recursive] Error 1
make[5]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib'
make[4]: *** [preinstall-recursive] Error 1
make[4]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4'
make[3]: *** [preinstall-stamp] Error 2
make[3]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c'
make: *** [all-recursive] Error 1
URL: <http://lists.rtems.org/pipermail/users/attachments/20141029/a9fc213f/attachment.html>
