The error in building rtems source about stm32f4 bsp
    ZhangZhenxing
    harbor0727 at gmail.com
    Thu Oct 30 01:07:27 UTC 2014
On 29/10/2014 8:05 AM, Joel Sherrill wrote:
> Sure. Hopefully Chris Nott will just reply to this thread when he
> spots it. :)
Quite correct, I missed a file. This patch should resolve it.
> On 10/29/2014 9:59 AM, ZhangZhenxing wrote:
>> Thank you very much!
>> can I receive the notice about the error if it is resolved?
>>     *From:* Joel Sherrill <mailto:joel.sherrill at oarcorp.com>
>>     *Date:* 2014-10-29 22:40
>>     *To:* ZhangZhenxing <mailto:harbor0727 at gmail.com>; users
>>     <mailto:users at rtems.org>; Chris Nott <mailto:chrisn at vl.com.au>
>>     *Subject:* Re: The error in building rtems source about stm32f4 bsp
>>     On 10/29/2014 9:07 AM, ZhangZhenxing wrote:
>>>     Hi,
>>>     I got the rtems source builder by the git command("git clone
>>>     git://git.rtems.org/rtems-source-builder.git") and builded rtems
>>>     4.11 toolschain by rtems source builder with the configure
>>>     command("../rtems-4.10.99/configure --target=arm-rtems4.11
>>>     --enable-posix --enable-networking --enable-cxx
>>>     --enable-rtemsbsp=stm32f4 --prefix=/opt/rtems-4.11/"). Then, when
>>>     executing "sudo make all install" after "./configure", there is a
>>>     error as follow. Why is it? How can I do for it? Thank you very
>>> much!
>>     I can confirm that I got the same message in a full build I ran
>>     Oct 26 but just now got a
>>     chance to look at. Using git blame, I see it was the last patch
>>     from Chris Nott[1]. It looks
>>     like the patch added some files to the Makefile.am but didn't
>>     include them.
>>     Chris.. if you can submit a patch which adds the new files, I will
>>     merge it quickly. At the
>>     moment, no stm32f*is building.
>> http://git.rtems.org/rtems/commit/?id=040ed0b4cdd1c663408664ba3a8b2e5de0cf54e0
>>     You could locally revert that patch and continue until it is
>>     resolved in the master. This is
>>     just part of using the development head. 99% of the time it is OK
>>     but once in a while,
>>     it isn't.
>>     [1] Sorry I missed having lunch or dinner with you. :)
>>>     make[8]: Entering directory
>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm/stm32f4'
>>>     /usr/bin/install -c -m 644
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/bsp_specs
>>>     ../../../../../.././stm32f4/lib/bsp_specs
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/tm27.h
>>>     ../../../../../.././stm32f4/lib/include/tm27.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/bsp.h
>>>     ../../../../../.././stm32f4/lib/include/bsp.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/coverhd.h
>>>     ../../../../../.././stm32f4/lib/include/coverhd.h
>>>     /usr/bin/install -c -m 644 include/bspopts.h
>>>     ../../../../../.././stm32f4/lib/include/bspopts.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/bootcard.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/bootcard.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/utility.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/utility.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-generic.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/irq-generic.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-info.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/irq-info.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/stackalloc.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/stackalloc.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/include/start.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/start.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/armv7m/include/armv7m-irq.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/armv7m-irq.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/irq.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/irq.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/usart.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/usart.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
>>>     ../../../../../.././stm32f4/lib/include/bsp/stm32f4.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_gpio.h
>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_gpio.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_rcc.h
>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_rcc.h
>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_exti.h
>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_exti.h
>>>     make[8]: *** No rule to make target `include/stm32f4xxxx_adc.h',
>>>     needed by
>>> `../../../../../.././stm32f4/lib/include/bsp/stm32f4xxxx_adc.h'.
>>>     Stop.
>>>     make[8]: Leaving directory
>>>     make[7]: *** [preinstall-recursive] Error 1
>>>     make[7]: Leaving directory
>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm'
>>>     make[6]: *** [preinstall-recursive] Error 1
>>>     make[6]: Leaving directory
>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp'
>>>     make[5]: *** [preinstall-recursive] Error 1
>>>     make[5]: Leaving directory
>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib'
>>>     make[4]: *** [preinstall-recursive] Error 1
>>>     make[4]: Leaving directory
>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4'
>>>     make[3]: *** [preinstall-stamp] Error 2
>>>     make[3]: Leaving directory
>>>     make[2]: *** [all-recursive] Error 1
>>>     make[2]: Leaving directory
>>>     make[1]: *** [all-recursive] Error 1
>>>     make[1]: Leaving directory
>>>     `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c'
>>>     make: *** [all-recursive] Error 1
>>     --     Joel Sherrill, Ph.D.             Director of Research &
>> Development
>>     joel.sherrill at OARcorp.com         On-Line Applications Research
>>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>     Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20141030/7f95b2c6/attachment.html>
