The error in building rtems source about stm32f4 bsp
    ZhangZhenxing
    harbor0727 at gmail.com
    Thu Oct 30 14:38:15 UTC 2014
On 10/29/2014 11:19 AM, Chris Nott wrote:
> On 29/10/2014 8:05 AM, Joel Sherrill wrote:
>> Sure. Hopefully Chris Nott will just reply to this thread when he
>> spots it. :)
> Quite correct, I missed a file. This patch should resolve it.
Patch is merged.
Thanks.
--joel
>> On 10/29/2014 9:59 AM, ZhangZhenxing wrote:
>>> Thank you very much!
>>> can I receive the notice about the error if it is resolved?
>>>     *From:* Joel Sherrill <mailto:joel.sherrill at oarcorp.com>
>>>     *Date:* 2014-10-29 22:40
>>>     *To:* ZhangZhenxing <mailto:harbor0727 at gmail.com>; users
>>>     <mailto:users at rtems.org>; Chris Nott <mailto:chrisn at vl.com.au>
>>>     *Subject:* Re: The error in building rtems source about stm32f4 bsp
>>>     On 10/29/2014 9:07 AM, ZhangZhenxing wrote:
>>>>     Hi,
>>>>     I got the rtems source builder by the git command("git clone
>>>>     git://git.rtems.org/rtems-source-builder.git") and builded rtems
>>>>     4.11 toolschain by rtems source builder with the configure
>>>>     command("../rtems-4.10.99/configure --target=arm-rtems4.11
>>>>     --enable-posix --enable-networking --enable-cxx
>>>>     --enable-rtemsbsp=stm32f4 --prefix=/opt/rtems-4.11/"). Then, when
>>>>     executing "sudo make all install" after "./configure", there is a
>>>>     error as follow. Why is it? How can I do for it? Thank you very
>>>> much!
>>>     I can confirm that I got the same message in a full build I ran
>>>     Oct 26 but just now got a
>>>     chance to look at. Using git blame, I see it was the last patch
>>>     from Chris Nott[1]. It looks
>>>     like the patch added some files to the Makefile.am but didn't
>>>     include them.
>>>     Chris.. if you can submit a patch which adds the new files, I will
>>>     merge it quickly. At the
>>>     moment, no stm32f*is building.
>>> http://git.rtems.org/rtems/commit/?id=040ed0b4cdd1c663408664ba3a8b2e5de0cf54e0
>>>     You could locally revert that patch and continue until it is
>>>     resolved in the master. This is
>>>     just part of using the development head. 99% of the time it is OK
>>>     but once in a while,
>>>     it isn't.
>>>     [1] Sorry I missed having lunch or dinner with you. :)
>>>>     make[8]: Entering directory
>>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm/stm32f4'
>>>>     /usr/bin/install -c -m 644
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/bsp_specs
>>>>     ../../../../../.././stm32f4/lib/bsp_specs
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/tm27.h
>>>>     ../../../../../.././stm32f4/lib/include/tm27.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/bsp.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/coverhd.h
>>>>     ../../../../../.././stm32f4/lib/include/coverhd.h
>>>>     /usr/bin/install -c -m 644 include/bspopts.h
>>>>     ../../../../../.././stm32f4/lib/include/bspopts.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/bootcard.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/bootcard.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/utility.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/utility.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-generic.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/irq-generic.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-info.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/irq-info.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/stackalloc.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/stackalloc.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/include/start.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/start.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/armv7m/include/armv7m-irq.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/armv7m-irq.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/irq.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/irq.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/usart.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/usart.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
>>>>     ../../../../../.././stm32f4/lib/include/bsp/stm32f4.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_gpio.h
>>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_gpio.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_rcc.h
>>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_rcc.h
>>>> ../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_exti.h
>>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_exti.h
>>>>     make[8]: *** No rule to make target `include/stm32f4xxxx_adc.h',
>>>>     needed by
>>>> `../../../../../.././stm32f4/lib/include/bsp/stm32f4xxxx_adc.h'.
>>>>     Stop.
>>>>     make[8]: Leaving directory
>>>>     make[7]: *** [preinstall-recursive] Error 1
>>>>     make[7]: Leaving directory
>>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm'
>>>>     make[6]: *** [preinstall-recursive] Error 1
>>>>     make[6]: Leaving directory
>>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp'
>>>>     make[5]: *** [preinstall-recursive] Error 1
>>>>     make[5]: Leaving directory
>>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib'
>>>>     make[4]: *** [preinstall-recursive] Error 1
>>>>     make[4]: Leaving directory
>>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4'
>>>>     make[3]: *** [preinstall-stamp] Error 2
>>>>     make[3]: Leaving directory
>>>>     make[2]: *** [all-recursive] Error 1
>>>>     make[2]: Leaving directory
>>>>     make[1]: *** [all-recursive] Error 1
>>>>     make[1]: Leaving directory
>>>>     `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c'
>>>>     make: *** [all-recursive] Error 1
>>>     --     Joel Sherrill, Ph.D.             Director of Research &
>>> Development
>>>     joel.sherrill at OARcorp.com         On-Line Applications Research
>>>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>     Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20141030/4ebcaf11/attachment.html>
