Bug in getcwd()
Wed Oct 1 18:10:58 UTC 2014
On 10/1/2014 9:26 AM, Rohner Thomas wrote:
> Hello,
> maybe I found a bug in getcwd().
> We’re using RTEMS 4.0 with Gaisler-Aeroflex….
> With our libraries I get an erroneous string when directory-depth is
> about 4 folders from root!
> When I use this string to read directory it crahes!
> Is there a limitation of string-length?
> I get the same results for
>                Char buffer[200];
> getcwd(buffer,sizeof(buffer));
> or
>                char* ret = getcwd(NULL,0);
Is this with the IMFS? What BSP?
Can you put together a full test example so we can
see what is really happening?
There is a POSIX constant for PATH_MAX as I recall but
it is quite large.
> Freundliche Grüsse / Kind regards,
> image001
> *Thomas Rohner***
> Entwicklungsingenieur Software
> nanoTRONIC GmbH
> Werkstrasse 27, CH - 3250 Lyss
> T: +41 32 384 69 30, F: +41 32 384 69 31
> www.nanotronic.ch <http://www.nanotronic.ch/> |
> thomas.rohner at nanotronic.ch <mailto:thomas.rohner at nanotronic.ch>
URL: <http://lists.rtems.org/pipermail/users/attachments/20141001/fe6de927/attachment-0002.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20141001/fe6de927/attachment-0002.jpe>
