Is it necessary to disable thread dispatching while functions of timer message are called ?
Tom
ventureg at 163.com
Mon Sep 1 00:25:50 UTC 2014
Hi all,
Is it necessary to disable thread dispatching while functions of timer message semaphore are called ?
For example , when the function `rtems_message_queue_send' is called, thread dispatching will be disabled due to
the _Object_Get call.
So unless `rtems_message_queue_send' is finished, other threads with higher priorities will not be allowed to run.
Is this necessary ? And why ?
Regards
Tom
URL: <http://lists.rtems.org/pipermail/users/attachments/20140901/43e3ff41/attachment.html>
