newlib fails to build
David Shifflett
shifflett at nps.edu
Thu Sep 4 23:42:38 UTC 2014
Thanks. That did the trick.
My build on Fedora 19 was successful.
dave
On 8/29/14 2:55 PM, Joel Sherrill wrote:
> You are missing the zlib-devel RPM. Perhaps the check could include headers and libraries. But this looks like GCC should check and fail also.
> On August 29, 2014 4:32:08 PM CDT, "Shifflett, David (CIV)" <shifflett at nps.edu> wrote:
>> Having gotten CVS access,
>> my build using the source builder progresses further,
>> but still fails.
>> I am running on Fedora 19.
>> ../source-builder/sb-check
>> says everything is ok.
>> ../source-builder/sb-set-builder --log=l-sparc.txt
>> --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
>> returns an error. Below is the end of the rsb report
>> ../../gcc-4.8.3/gcc/lto-compress.c:28:18: fatal error: zlib.h: No such
>> file or directory
>> #include <zlib.h>
>> compilation terminated.
>> make[2]: *** [lto-compress.o] Error 1
>> make[2]: Leaving directory
>> `/home/user/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-19-Aug-2014-1/build/gcc'
>> make[1]: *** [all-gcc] Error 2
>> make[1]: Leaving directory
>> `/home/user/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-19-Aug-2014-1/build'
>> make: *** [all] Error 2
>> shell cmd failed: /bin/sh -ex
>> /home/user/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-19-Aug-2014-1/doit
>> error: building sparc-rtems4.11-gcc-4.8.3-newlib-19-Aug-2014-1
>> I did a search for zlib.h and found it at
>> ~/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-19-Aug-2014-1/gcc-4.8.3/zlib/zlib.h
>> Any help would be appreciated,
>> Thanks,
>> dave
>> users mailing list
>> users at rtems.org
