No rule to make target `src/clockgettickssinceboot.c'
Nick Withers nick.withers at anu.edu.au
Thu Sep 11 06:44:51 UTC 2014
On Thu, 2014-09-11 at 08:27 +0200, Sebastian Huber wrote:
> On 11/09/14 08:18, Nick Withers wrote:
> > Hi all,
> > Git pulled today and rebuilt tools (with RSB), building RTEMS/4.11 for
> > the mvme3100 BSP failed with:
> > ____
> > powerpc-rtems4.11-gcc --pipe -DHAVE_CONFIG_H   -I.. -I../../cpukit/../../../mvme3100/lib/include   -mcpu=powerpc -msoft-float -D__ppc_generic -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT src/librtems_a-clockgetsecondssinceepoch.o -MD -MP -MF src/.deps/librtems_a-clockgetsecondssinceepoch.Tpo -c -o src/librtems_a-clockgetsecondssinceepoch.o `test -f 'src/clockgetsecondssinceepoch.c' || echo '../../../../../../../rtems/c/src/../../cpukit/rtems/'`src/clockgetsecondssinceepoch.c
> > mv -f src/.deps/librtems_a-clockgetsecondssinceepoch.Tpo src/.deps/librtems_a-clockgetsecondssinceepoch.Po
> > powerpc-rtems4.11-gcc --pipe -DHAVE_CONFIG_H   -I.. -I../../cpukit/../../../mvme3100/lib/include   -mcpu=powerpc -msoft-float -D__ppc_generic -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT src/librtems_a-clockgettickspersecond.o -MD -MP -MF src/.deps/librtems_a-clockgettickspersecond.Tpo -c -o src/librtems_a-clockgettickspersecond.o `test -f 'src/clockgettickspersecond.c' || echo '../../../../../../../rtems/c/src/../../cpukit/rtems/'`src/clockgettickspersecond.c
> > mv -f src/.deps/librtems_a-clockgettickspersecond.Tpo src/.deps/librtems_a-clockgettickspersecond.Po
> > gmake[5]: *** No rule to make target `src/clockgettickssinceboot.c', needed by `src/librtems_a-clockgettickssinceboot.o'.  Stop.
> You should delete the build tree and do a bootstrap.
Ahem. Oops!
Thanks again...
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
