Issue working with rtemsTimer
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Sep 15 20:12:26 UTC 2014
The timer method runs inside the clock tick ISR and you can't call printf() from an interrupt. At least that is what I spot first.
Also easy in C++ to do something in an ISR you shouldn't.
On September 15, 2014 3:05:03 PM CDT, "Martínez, Pablo" <pabloa.mar at gmail.com> wrote:
>Hi guys,
>Im trying to implement a single shot timer.
>I derive from rtemsTimer class and replace virtual void triggered()=0
>#include <rtems++/rtemsTimer.h>
>class Timer : public rtemsTimer {
>public:
> Timer(const char* tname);
> virtual ~Timer();
>private:
> void triggered();
>in timer.cpp
>void SynchTimer::triggered(){
> printf("hello Timer! \n");
>Then I have the following task class who creates and fires a Timer
>object:
>class TimerMngr : public rtemsTask{
>public:
> TimerMngr(const char* tname);
> virtual ~TimerMngr();
>private:
> void body(rtems_task_argument argument);
>in timerMngr.cpp
>TimerMngr::TimerMngr(const char* tname)
>: rtemsTask(tname,
> 1,
> RTEMS_MINIMUM_STACK_SIZE,
> RTEMS_PREEMPT|RTEMS_TIMESLICE,
> 0,
> RTEMS_NO_FLOATING_POINT,
> RTEMS_LOCAL)
> if(last_status_code()!=RTEMS_SUCCESSFUL)
> printf("SynchMngr::error when create()%d \n",
> last_status_code());
>void TimerMngr::body(rtems_task_argument argument){
> printf("TimerMngr::body! \n"); [1]
> /* Create the Timer
> Timer* timer=new Timer("timer");
> printf("SynchMngr, CurrentTime! @ %d \n",getCurrentTime()); [2]
> /* start timer
> rtems_status_code status;
> status=synch_timer->fire_after(120);
> printf("synch_timer->fire_after() status %d \n",status); [3]
> wake_after(500);
> printf("SynchMngr, CurrentTime @ %d \n",getCurrentTime()); [4]
>unsigned TimerMngr::getCurrentTime(){
> //rtems_unsigned32 time_stamp;
> unsigned time_stamp;
> time_stamp=0;
>status=rtems_clock_get(RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH,&time_stamp);
> if(status!=RTEMS_SUCCESSFUL)
> printf("error with rtems_clock_get %d \n",status);
> return time_stamp;
>When I run the app I get the first and second printf [1] y [2]. But
>just
>"syn" from the 3erd printf [3].
>In the conf file:
>#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>#define CONFIGURE_TICKS_PER_TIMESLICE 30
>#define CONFIGURE_MAXIMUM_TIMERS 4
>Any suggestion?
>Cheers,
>Pablo
>Martínez, Pablo Agustín
URL: <http://lists.rtems.org/pipermail/users/attachments/20140915/4300fc52/attachment.html>
