generall RTEMS questions
Fri Sep 26 16:18:44 UTC 2014
On September 26, 2014 12:36:20 AM CDT, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>Hello Marco,
>On 19/09/14 11:15, Hoefle Marco wrote:
>> Hello,
>> we have currently the RTEMS sources from Gaisler in use (as they have
>their
>> drivers not in mainline RTEMS, unfortunately).
>> The Gaisler RTEMS kernel is based on 4.10.
>> However, a few useful features are only available in 4.11 (JFFS2 File
>system
>> for example).
>> We are thinking on moving to 4.11 but we are wondering if there is a
>proper
>> tested stable version available. In 4-10 are tags in 4-11 I did not
>find one.
>> Would you recommend using 4.11 in a production environment?
>RTEMS 4.11 is work in progress.  If you are lucky and select the right
>commit,
>then it is a production ready version.  It helps to rely on companies
>working
>daily with the system doing regular tests if you want to do serious
>business
>with RTEMS.
>> We use rtems source builder which works fine. However, we still do
>not
>> understand why is there such a dependency toolchain – rtems kernel?
>There is an interaction between Newlib (the C library) and RTEMS.  Some
>parts
>are defined in Newlib header files and implemented in RTEMS source
>files.
And changing the GCC version gets you out of sync up with testing. Different gcc versions can have new optimizations that break the code, bugs, or generate new warnings.
>> Why can’t the standard gcc be used to compile the rtems bsp in an
>archive and
>> linked to the application afterwards?
>The problem is not GCC.  GCC and Newlib are built together.
But the GCC configuration is tweaked to be RTEMS specific and not generic elf or Linux. The runtime libraries are compiled using Newlib in the RTEMS configuration. There is not a large difference between say sparc-elf and sparc-rtems at the toolset source level but the resulting GCC and Newlib are different.
Ultimately a test with a specific configuration of tools and if you deviate from that, it can be OK or not.
