Memory protection in RTEMS
Mohammed Saeed Khoory Mohammed.Khoory at eiast.ae
Thu Apr 9 04:12:10 UTC 2015
Hi,
I find this topic interesting as well. I've had a general question about memory protection that I was hoping someone knowledgeable could shed light on.
I've noticed that some RTOS's (not just RTEMS) don't implement memory protection and prefer to stay that way. I think real-time Linux also explicitly disables memory protection by having real-time tasks run in kernel mode. Is there something about memory protection that makes it disadvantageous to real-time computing in general? Does it introduce non-determinism? Or is it in order to reduce complexity, and maybe to keep the address space flat and simple?
Thanks!
> -----Original Message-----
> From: users [mailto:users-bounces at rtems.org] On Behalf Of Gedare Bloom
> Sent: Thursday, April 02, 2015 7:39 PM
> To: Tomasz Gregorek
> Cc: users at rtems.org
> Subject: Re: Memory protection in RTEMS
> On Thu, Apr 2, 2015 at 11:19 AM, Tomasz Gregorek
> <tomasz.gregorek at gmail.com> wrote:
> > Hi Gedare
> > Thank you for your comments, they answer my question.
> > We will look at other RTOSes this time.
> OK, I'd be happy to hear what you find or settle on. It's a topic that I
> have continued interest in working on for RTEMS.
> Gedare
> > Thanks
> > Tomasz
> > 2015-04-02 17:01 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> >> Hi Tomasz,
> >> It is possible to implement some memory protection between threads.
> >> As you noticed, RTEMS is a SASOS with "one process" when viewed from
> >> the POSIX interface. Generalizing memory protection in such a system
> >> is hard. The most common approach I know of is to provide separate
> >> protection domains for each thread stack. In theory, you could create
> >> a protection domain for the RTEMS "kernel", but I'm not aware of
> >> anyone that has tried hard to do that. You may also look for the
> >> "Zero Kernel" work some folks did as a research project at Univ of
> >> Idaho I think it was.
> >> If you want memory protection, you'd have to tailor it to your
> >> specific application requirements and set-up the MMU/MPU to do it.
> >> Final note: Since there is no notion of privilege in RTEMS, any
> >> thread can always disable or modify the protection domains since
> >> priviliged registers and instructions are available. Thus, while you
> >> may add memory protection, it would not be for a complete security
> solution.
> >> Gedare
> >> On Thu, Apr 2, 2015 at 10:04 AM, Tomasz Gregorek
> >> > Hi
> >> > We are investigating possible OSes for a new product where one of
> >> > the requirements is memory protection between processes.
> >> > Does RTEMS supports memory protection? If not than is it planned to
> >> > implement memory protection?
> >> > This is what I found so far:
> >> > RTEMS is single process, multiple threads and as such have
> >> > everything in single memory space.
> >> > http://comments.gmane.org/gmane.os.rtems.user/19858
> >> > Gedare's blog with his implementation of memory protection from
> >> > 2011/2012.
> >> > http://gedare-csphd.blogspot.be/2011/12/rtems-memory-protection-api
> >> > .html but it seems that this code didn't get to the main.
> >> > Project "MMU Support" by Aanjhan Ranganathan from 6 years ago:
> >> > https://devel.rtems.org/wiki/Projects/MMU_Support
> >> > Source code configures MMUs but it seems it do it to enable cache
> >> > only, not the memory protection. Though I did only simple search
> >> > through the code.
> >> > There are exception handlers for some architectures/CPUs but only
> >> > for few if not for only one.
> >> > Best regards
> >> > Tomasz Gregorek
> >> > _______________________________________________
> >> > users mailing list
> >> > users at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
