RSB fails at building sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
Hyungshin Kim kvkim10 at gmail.com
Mon Apr 20 04:31:14 UTC 2015
I am installing RTEMS tools with RSB. While I was running the
$ ../source-builder/sb-set-builder
--prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
as shown on the web, after 20 min, I got the build fail message as below.
building: sparc-rtems4.11-gcc-4.9.2-newlib-2.2.0.20150323-x86_64-linux-gnu-1
config: tools/rtems-gdb-7.9-1.cfg
package: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
building: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
error: building sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
Build FAILED
  See error report:
rsb-report-sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.txt
Build Set: Time 0:14:24.333754
Build FAILED
In the rsb-report-sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.txt file, it
contains some info
as follows.
checking whether to use python... yes
checking for python... /usr/bin/python
checking for python2.7... no
configure: error: python is missing or unusable
make[1]: *** [configure-gdb] Error 1
make[1]: Leaving directory
`/home/eslab/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex
 /home/eslab/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/doit
Can anyone help me what is going on ?
Kevin
URL: <http://lists.rtems.org/pipermail/users/attachments/20150420/d2bacfc8/attachment.html>
