compile RTEMS failed.
Mon Apr 20 07:27:50 UTC 2015
This should be fixed already, so please update to the latest Git master.
On 20/04/15 09:25, Rafael wong wrote:
> Hi,
>     I am a new user, I am trying to compile RTEMS with ARM and
> s3c2410bsp follow QuickStart, but failed.
>     The error was that it can not find header file <drvmgr/drvmgr.h>
> when compiling cpukit/libmisc/shell/main_drvmgr.c.
>     Please help me, Thank you!
> Enviroment: Ubuntu 14.10
> The command build RSB:
>    $ ../source-builder/sb-set-builder
> --prefix=$HOME/development/rtems/4.11 4.11/rtems-arm
> The command configure RTEMS:
>    $ ../rtems/configure --target=arm-rtems4.11
> --enable-rtemsbsp=smdk2410  --enable-tests=samples --enable-posix
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
