Netdemo with Altera Cyclone V SoC development kit
Wed Apr 22 06:37:41 UTC 2015
Maybe your PHY is not properly configured (clock skew values, etc.).
On 21/04/15 22:25, Adit Sahasrabudhe wrote:
> Just bumping this as I’m at a bit of a loss on it.
> I’ve tried connecting the board to an Ixia traffic generator to send
> ARP requests, but the board does not respond. Additionally, the UDP
> traffic that the netdemo thinks it sends out is not seen at all at the
> other end. I feel like there is just some configuration of the driver
> that I am missing. I have tried the demo in loopback mode and it seems
> to be ok.
> Thanks,
> Adit
> From: Adit Sahasrabudhe <asahasra at fb.com <mailto:asahasra at fb.com>>
> Date: Tuesday, April 7, 2015 at 1:55 PM
> To: "users at rtems.org <mailto:users at rtems.org>" <users at rtems.org
> <mailto:users at rtems.org>>
> Subject: Netdemo with Altera Cyclone V SoC development kit
> Hi,
> I’m wondering if anyone has experience running the netdemo example on
> the Altera Cyclone V SoC development kit? The problem I’m having seems
> to be related to ARP tables, but I’m not quite sure.
> My setup:
> Host PC – Centos 6.6, using Eclipse to load and debug code. IP address
> of 192.168.0.5
> Target board – Altera CV development kit, running netdemo example. IP
> address of 192.168.0.2 (see attached networkconfig.h file)
> These systems are on a local network connected to each other via an
> ethernet switch, and are the only two devices attached. I have
> wireshark running on my host computer and it never sees any traffic
> from the device. The host is continually sending ARP requests that go
> unanswered. As a result, when I try to telnet or ping the device, I
> get the error “no route to host”. I can send the ‘u’ command to
> netdemo and it says it transmits UDP packets to 192.168.0.5, but again
> nothing shows up on wireshark. I have also attached the log from
> netdemo showing the ‘u’ and ’s’ commands.
> Any insight is greatly appreciated.
> Adit
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
