Basic Workflow With Zynq BSPs?
Jonathan Brandmeyer jonathan.brandmeyer at gmail.com
Wed Apr 22 17:23:36 UTC 2015
I've managed to get the demo applications to run on the microzed with the
following workflow:
-Build the RTEMS xilinx_zynq_zedboard BSP as normal
-Build a basic FPGA bitstream, Xilinx BSP, and first-stage bootloader
(FSBL) as described in the first few tutorials for the microzed.  The FSBL
references the BSP, which in turn references the hardware-specific
configuration settings provided by Xilinx' tools.  Xilinx BSP is actually a
complete freestanding C environment + hardware setup code and drivers.
- Package a BOOT.BIN file composed of the FSBL, fpga bitstream, and an
RTEMS demo program.  BUT, rename the demo application to have the suffix
.elf instead of .exe so that the Xilinx "bootgen" utility correctly
identifies the entry point of the RTEMS ELF file.
This seems to work OK for the RTEMS demo programs.  But, some notes in the
RTEMS BSP's history and source code suggest that this may be insufficient.
In particular, there are notes referring to the need for the application to
specify the system clock frequency, UART freq, and/or MMU tables,
presumably based on the exported hardware definitions and/or Xilinx BSP for
the processor.
My questions are:
- Does the Xilinx BSP's C environment conflict with the RTEMS C
environment?  A Xilinx BSP's libxil.a is compiled by default with a
Xilinx-provided toolchain (arm-xilinx-eabi-tool), while RTEMS is built with
an rtems-specific toolchain.  Is it sufficient to simply rebuild the Xilinx
BSP with the RTEMS toolchain instead?
- To what extent can you perform custom setup tasks that rely on the Xilinx
BSP by modifying their FSBL?  Conversely, what Xilinx BSP-specific tasks
must be performed by the RTEMS application instead?  The RTEMS BSP seems to
be sufficient to run simple applications like 'ticker' without pulling in
the Xilinx BSP at all.
- Is it reasonable to maintain the Xilinx FSBL + RTEMS application
separation?  It seems to work OK with their tools that way.  Or does it
seem better in practice to integrate the FSBL's functionality into an
RTEMS-hosted application?
Thanks,
Jonathan Brandmeyer
URL: <http://lists.rtems.org/pipermail/users/attachments/20150422/596d7cde/attachment.html>
