CPU/board selection
Mathew Benson mathew.benson at gmail.com
Fri Apr 24 18:27:53 UTC 2015
I intended to run bare metal code on the microblaze.  The microcontroller is for I/O and high rate control laws.  Between 600Hz and 8kHz.  I assumed I wouldn't run an RTOS on that.  Or is RTEMS on the microcontroller still an option?
Sent from my iPhone
> On Apr 24, 2015, at 11:23 AM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> On 4/24/2015 11:20 AM, Mathew Benson wrote:
>> I'm trading building a custom board with purchasing a COTS board for a project.  My prototype dev board is a Beaglebone Black running Linux with preemptive kernel and the real time Xenomai micro kernel.  I would like to port my project to RTEMS on a CPU with either an embedded microcontroller like the PRU in the Beaglebone Black, or preferably an FPGA with hardcore and hard/softcore microcontroller like a Zynq with microblaze.  Can somebody recommend a solution that is confirmed to work with RTEMS?  Either RTEMS from the main line, or possibly a custom and/or commercial solution.
> The Zynq with ARM is known to work well including SMP.
> A Microblaze port has never been submitted but contact me offline
> and I will explain the situation.
>> Sent from my iPhone
>> users mailing list
>> users at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
