Coverage Analysis on rtems 4.10 of switch case structures
Juanma Mail List
greenlean.maillist at gmail.com
Wed Apr 29 08:46:35 UTC 2015
Hello,
I am doing a coverage analysis for a software code which is based on
RTEMS 4.10 and runs on a sparc-leon3 platform from Gaisler. I have
problem with the coverage of switch-case structures.
The software mostly processes the commands that are send to it, and do
the actions associated to the them. To do the coverage, I have added
some wrappers and compiled the software as a static library.
And finally a set of test application do the call to the library and
check the coverage.
My framework uses:
- TSIM/LEON3 SPARC simulator, version 2.0.19 (professional version).
- covoar tool and leon3 simulation script from rtems-testing tools.
- sparc-rtems-gcov, lcov and genhtml.
I am not able to cover the switch-case structures. The coverage shows
that the execution always hit the first case of the switch-case.
Does anyone seen this behavior before?
Many thanks, Juanma.
*$ *sparc-rtems-gcc -v
Reading specs from /opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.6/specs
Target: sparc-rtems
Configured with: ../../gcc/configure --target=sparc-rtems
--with-gnu-as --with-gnu-ld --with-newlib --verbose --enable-threads
--enable-languages=c,c++ --disable-nls --prefix=/opt/rtems-4.10
--enable-version-specific-runtime-libs --with-system-zlib
--disable-libstdcxx-pch --disable-win32-registry --without-included-gettext
Thread model: rtems
gcc version 4.4.6 (GCC)
*$* sparc-rtems-gcov -v
gcov (GCC) 4.4.6
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE.
The tests are compiled wth the flags
CCFLAGS = -fprofile-arcs -ftest-coverage
LDFLAGS = -lgcov -coverage
My coverage script:
./leon3 -c -l 120 simpletest.exe
echo "Cleaning counters and create intial..."
lcov --zerocounters --directory "$SOURCE_DIR" > log/gcov.log 2>&1
lcov --capture --initial --directory "$SOURCE_DIR" --output-file
"$OUTPUT_DIR/coverage.info" --gcov-tool "$GCOV" >> log/gcov.log 2>&1
covoar -v -C config $TESTSUITE >> log/gcov.log 2>&1
lcov --no-checksum -d $SOURCE_DIR --capture --output-file
"$OUTPUT_DIR/coverage.info" --gcov-tool $GCOV --config-file
../rtemsNOMAD/sfs.lcovrc >> log/gcov.log 2>&1
echo "Generating report $OUTPUT_DIR/$REPORTDIR"
genhtml --highlight --legend --output-directory
"$OUTPUT_DIR"/"$REPORTDIR" coverage.info --config-file
URL: <http://lists.rtems.org/pipermail/users/attachments/20150429/033b4773/attachment-0001.html>
