build Graphics Tool Kits for PC386
QIAO YANG yangqiao0505 at me.com
Fri Apr 3 20:19:26 UTC 2015
Hi Pavel Pisa,
Thanks for your reply with patience.
In order to confirm that I didn't mess up the path or something, I've cleaned up and re-built everything.
The problem is so weird because I had set the path correctly. What I learned from the log is that, libraries libjpeg , libfreetype, libpng, libt1, libtiff, libnanox, libX11 has been successfully compiled and installed, which cannot be found during the compilation of microwin and fltk. Only few executable has been built for microwin  :  convbmp, makebmp, convbdf. I can hardly tell anything from the log the reason why it can't find the installed libraries. I'm trying to look into the
My text editor hide the files .a automatically so I didn't see the installed libraries for microwin until I open the folder in browser ... Yes all has been compiled and installed successfully except for fltk.
As the excutables cannot be compiled, I don't have any of those demos.  I'm trying the rtems test framework and I'll update later.
As for the harmless freetype2 error, the removal of non-existing directory is not a bug. It's used to ensure that we have removed the internal for old version.
Thanks for your patience.
Regards
On Apr 01, 2015, at 04:52 PM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Hello Qiao Yang,
> thanks for the progress report.
> On Wednesday 01 of April 2015 01:42:04 QIAO YANG wrote:
>> I've cleaned and recompiled it with the latest rtems4.11 and gtk from
>> github, and also the microwin and the nxlib from alex's fork, apply the
>> microwin patch manually(as for the commit number doesn't exist). From the
>> build log, It seems that many tests have failed for microwin due to
>> "undefined reference". The full build log is here the link to my evernote.
>> https://www.evernote.com/shard/s271/sh/de7200c2-721b-47e5-b3b4-924b33483ec2/bb22975157ac49766edc434ec2af9e0a
> As for Microwindows, we have successfully builded Microwindows
> and used /opt/rtems4.11/.... installed libraries for more own
> test on x86 and ARM even our complete production ARM RTEMS 4.10
> application could be compiled against 4.11 with actual Graphics Tool Kit.
> But there may be some demos in Microwindows sources which do not build
> according for RTEMS (I will recheck with actual RTEMS sources).
> There is list of executables which as been successfully compiled
> in my Microwindows build
> rtems-graphics-toolkit/build/microwin/src/bin
> move world nxmag bmpdemo makebmp nxkbd convbdf setportrait nxview npanel slider demo polydemo mdemo mwdvetest.res mine landmine arcdemo mtest2
> grabdemo tux tuxchess fonts fontdemo setselection convbmp pcfdemo logfont nxclock mwdvetest malpha ntetris nsaver monobitmap nxev demo2 dashdemo
> blitdemo tsdemo getselection nxeyes demo5 nxlsclients nxcal launcher mtest nxscribble rgndemo t1demo composite snap_ppm ftdemo demo6 nxroach
> The malpha is good/know to work candidate for testing
> I run it by
> qemu-system-x86_64 -gdb tcp::1234 -enable-kvm -kernel ./malpha \
> -vga cirrus \
> -net nic,vlan=0,model=e1000 -net user,vlan=0 \
> -append "--console=com1"
> But you can/should use standard RTEMS testing framework which can found
> in
> git://git.rtems.org/rtems-testing.git
> Back to your log
> make[3]: *** No rule to make target '-ljpeg', needed
> by '/home/yangqiao/development/rtems-386/rtems-graphics-toolkit/build/microwin/src/bin/nxscribble'.
> make[3]: *** No rule to make target '-lfreetype', needed
> make[3]: Target 'all' not remade because of errors.
> make[3]: Leaving directory '/home/yangqiao/development/rtems-386/rtems-graphics-toolkit/build/microwin/src/demos/nxscribble'
> /home/yangqiao/development/rtems-386/rtems-graphics-toolkit/build/microwin/src/Makefile.rules:527: recipe for
> target 'subdir-/home/yangqiao/development/rtems-386/rtems-graphics-toolkit/build/microwin/src/demos/nxscribble/' failed
> I see some problems caused problem to find some libraries.
> You should find these libraries installed in /opt/rtems4.11
> after
> ./do_it -A
> /opt/rtems4.11/i386-rtems4.11/pc686/lib/libjpeg.a
> libpng.a -> libpng15.a
> etc.
> If they are not there then it is necessary to find why they have not been
> installed. They can be copied there from Graphics Tool Kit build manually
> to check the rest of the build. But the problem should be resolved.
> This problem seems to propagate to other components as well.
> But generally, Microwindows libraries (not demos) seems to be fully compiled.
> Real problem appears in the build of FLtk
> /home/yangqiao/development/rtems-386/rtems-graphics-toolkit/build/fltk-1.3.0/
> But even there many of tests build
> Compiling Fl_PNG_Image.cxx...
> Compiling Fl_PNM_Image.cxx...
> /home/yangqiao/development/rtems-386/compiler/4.11/bin/i386-rtems4.11-ar cr ../lib/libfltk_images.a ...
> === making test ===
> Compiling unittests.cxx...
> Linking unittests...
> Compiling adjuster.cxx...
> Linking adjuster...
> Compiling arc.cxx...
> Compiling buttons.cxx...
> Linking buttons...
> Compiling cairo_test.cxx...
> Linking cairo_test...
> /home/yangqiao/development/rtems-386/bsps/4.11/i386-rtems4.11/pc386/lib/libnano-X.a(image_jpeg.o): In function `GdDecodeJPEG':
> /home/yangqiao/development/rtems-386/rtems-graphics-toolkit/build/microwin/src/engine/image_jpeg.c:118: undefined reference to `jpeg_std_error'
> Yet there seems to be problem with finding JPEG library.
> As for Fluid (graphical GUI designer tool), it fails but that is expected, because
> it has no purpose to be build for RTEMS. There is required native Linux executable to
> be build even for RTEMS target design
> Compiling ../fluid/fluid.cxx...
> Linking ../fluid/fluid...
> ../fluid/fluid.o: In function `save_template_cb(Fl_Widget*, void*)':
> /home/yangqiao/development/rtems-386/rtems-graphics-toolkit/build/fltk-1.3.0/test/../fluid/fluid.cxx:237: undefined reference to `template_panel'
> But generally, I have newer used FLtk with RTEMS and I expect that there
> is quite huge amount of work left to make it usable on RTEMS.
> It requires to compile (or use actual RTEMS 4.11 dlopen) to include
> X style window manager in actual running RTEMS system to be able to manage
> FLtk windows.
> But that could be great target and usesfull target for your
> or some others work
> BUT GRAPHIC TEST LOADED BY NEW DLOPEN COULD BE GEAR AND
> REALLY USESFULL TARGET FOR YOUR OR SOME OTHERS WORK
> Because today it is possible to build base RTEMS system
> with drivers and may it be base Graphics Tool Kit
> libraries compiled in basic system image and then load
> all test dynamically under some scrips requests and prepare
> some guidepost type gui for manual iteration through tests.
>> Here is an error of freetype
>> at line 2119 of build log:
>> rmdir: failed to remove
>> ‘/home/yangqiao/development/rtems-386/bsps/4.11/i386-rtems4.11/pc386/lib/in
>> clude/freetype2/freetype/internal’: No such file or directory
>> /home/yangqiao/development/rtems-386/rtems-graphics-toolkit/freetype-2.4.10
>> /builds/unix/install.mk:31: recipe for target 'install' failed make:
>> [install] Error 1 (ignored)
>> I've read that the freetype2 didn't use internal folder anymore after a
>> release of 2012. It's not a fatal error here and it's ignored. But I wonder
>> if the tests still use some headers from it which may cause the massive
>> undefined references ( I know little about the detail, just a personal
>> suspicion).
>> As for the rest errors, you may know them much better :), I'll also try to
>> find out .
> Please, try to check what is a problem and send report.
> Try to correct freetype-2.4.10/builds/unix/install.mk to resolve the
> error and run build again. You should have all sources
> in GIT repositories so your modification are
> easily found by
> git diff
> (cd microwin && git diff)
> (cd nxlib && git diff)
> Best wishes,
> Pavel
URL: <http://lists.rtems.org/pipermail/users/attachments/20150403/dd90bb2d/attachment-0002.html>
