Coverage Analysis on rtems 4.10 of switch case structures
Juanma Gomez jmgomez at iaa.es
Thu Apr 30 12:41:29 UTC 2015
Hola Aitor,
     Sorry I sent the email from the incorrect email address.
     We are actually using the sparc-rtems-gcov tool, but same result
for sparc-elf-gcov.
*$ which sparc-elf-gcov *
/opt/bcc-src-1.0.42/bin/sparc-elf-gcov
*$ which sparc-rtems-gcov *
/opt/rtems-4.10/bin/sparc-rtems-gcov
I have prepared an example in order to show you the results:
This will be our test suit, both functions are executeCommand and
executeCommand2 are in a static library.
     i = 1;
     while(i < 10){
         wrValue = *executeCommand(i);*
         wrValue = *executeCommand2(i);*
         i ++;
executeCommand always use case 0 and default, on the other side
executeCommand2 is complete covered.
   0           2 : int executeCommand(int cmd){
       11             :   unsigned char a;
       12           2 :   switch(cmd){
       13             :
       14             :     case 0:
       15           1 :         a = 10;
       16           1 :         break;
       17             :     case 1:
       18           0 :         a = 16;
       19           0 :         break;
       20             :     case 2:
       21           0 :         a = 21;
       22           0 :         break;
       23             :     case 3:
       24           0 :         a = 31;
       25           0 :         break;
       26             :     default:
       27           1 :         a =  -1;
       28             :         break;
       29             :
       30             :   }
       31             :
       32           2 :   return a;
       33             :
       34             : }
       35             :
       36           1 : int executeCommand2(int cmd){
       37             :   unsigned char a;
       38             :
       39           1 :   a =  -1;
       40             :
       41           1 :   if(cmd == 0)
       42           0 :         a = 10;
       43             :
       44           1 :   if (cmd==1 )
       45           1 :         a = 16;
       46             :
       47           1 :   if (cmd == 2)
       48           1 :       a = 21;
       49             :
       50           1 :   if (cmd == 3)
       51           1 :         a = 31;
       52             :
       53           1 :   return a;
       54             :
       55             : }
I use covoar to convert the coverage data generated from TSIM-LEON3 to
lcov data.
simpleSW.syms
_GLOBAL__I_65535_0_executeCommand
/media/data/proyecto/Nomad/leon3-sw/coverage-test0/simpleLib/simpleSW.o
executeCommand
executeCommand2
simpleSW.gcnos
/media/data/proyecto/Nomad/leon3-sw/coverage-test0/simpleLib/simpleSW.gcno
This is part of the output of gcov tool. It looks like it is actually
receiving the data from TSIM or Covoar with that error.
Processing file:
Computing uncovered ranges and branches
Branch always taken found in executeCommand (0x4000151c - 0x4000151f)
Branch always taken found in executeCommand2 (0x40001690 - 0x40001693)
Could you provide me some information of how to verify the correctness
of the coversion of the covoar tool and the tsim output. Maybe I could
check the file a locate if the problem comes from tsim, covoar or
sparc-rtems-gcov.
Thanks, Juanma.
On 04/30/2015 10:22 AM, Aitor Viana Sanchez wrote:
> Hola Juanma,
> are you using sparc-gcov <https://github.com/aitorvs/sparc-gcov>? I
> don’t remember whether I ever had a problem with switch-case while
> developing/testing the tool. If you’re using it and its a bug send me
> some files so I can reproduce the problem and fix the bug.
> If you’re using another gcov wrapper, have a look at sparc-gcov and
> see whether it fixes the problem.
> regards
> //avs
> On 29/04/15 10:46, Juanma Mail List wrote:
>> Hello,
>> I am doing a coverage analysis for a software code which is based on
>> RTEMS 4.10 and runs on a sparc-leon3 platform from Gaisler. I have
>> problem with the coverage of switch-case structures.
>> The software mostly processes the commands that are send to it, and
>> do the actions associated to the them. To do the coverage, I have
>> added some wrappers and compiled the software as a static library.
>> And finally a set of test application do the call to the library and
>> check the coverage.
>> My framework uses:
>>     - TSIM/LEON3 SPARC simulator, version 2.0.19 (professional version).
>>     - covoar tool and leon3 simulation script  from rtems-testing tools.
>>     - sparc-rtems-gcov, lcov and genhtml.
>> I am not able to cover the switch-case structures. The coverage shows
>> that the execution always hit the first case of the switch-case.
>> Does anyone seen this behavior before?
>> Many thanks, Juanma.
>> *$ *sparc-rtems-gcc -v
>>         Reading specs from
>> /opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.6/specs
>>         Target: sparc-rtems
>>         Configured with: ../../gcc/configure --target=sparc-rtems
>> --with-gnu-as --with-gnu-ld --with-newlib --verbose --enable-threads
>> --enable-languages=c,c++ --disable-nls --prefix=/opt/rtems-4.10
>> --enable-version-specific-runtime-libs --with-system-zlib
>> --disable-libstdcxx-pch --disable-win32-registry
>> --without-included-gettext
>>         Thread model: rtems
>>         gcc version 4.4.6 (GCC)
>> *$* sparc-rtems-gcov -v
>>     gcov (GCC) 4.4.6
>>     Copyright (C) 2010 Free Software Foundation, Inc.
>>     This is free software; see the source for copying conditions.
>>     There is NO warranty; not even for MERCHANTABILITY or
>>     FITNESS FOR A PARTICULAR PURPOSE.
>> The tests are compiled wth the flags
>>         CCFLAGS =  -fprofile-arcs -ftest-coverage
>>         LDFLAGS = -lgcov -coverage
>> My coverage script:
>> ./leon3 -c -l 120 simpletest.exe
>> echo "Cleaning counters and create intial..."
>> lcov --zerocounters --directory "$SOURCE_DIR" > log/gcov.log 2>&1
>> lcov --capture --initial --directory "$SOURCE_DIR" --output-file
>> "$OUTPUT_DIR/coverage.info" --gcov-tool "$GCOV" >> log/gcov.log 2>&1
>> covoar -v -C config $TESTSUITE >> log/gcov.log 2>&1
>> lcov --no-checksum -d $SOURCE_DIR  --capture --output-file
>> "$OUTPUT_DIR/coverage.info" --gcov-tool $GCOV --config-file
>> ../rtemsNOMAD/sfs.lcovrc >> log/gcov.log 2>&1
>> echo "Generating report $OUTPUT_DIR/$REPORTDIR"
>> genhtml --highlight --legend --output-directory
>> "$OUTPUT_DIR"/"$REPORTDIR"  coverage.info --config-file
>> users mailing list
>> users at rtems.org
> This message and any attachments are intended for the use of the addressee or addressees only.
> The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
> content is not permitted.
> If you received this message in error, please notify the sender and delete it from your system.
> Emails can be altered and their integrity cannot be guaranteed by the sender.
> Please consider the environment before printing this email.
Juan Manuel Gómez López
Instituto de Astrofísica de Andalucía (IAA)
Unidad de Desarrollo Instrumental y Tecnológico (UDIT)
Glorieta de la Astronomía s/n 18008 Granada
Teléfono centralita: +34 958 121 311
Teléfono directo: +34 958 230 574
FAX: +34 958 814 530
URL: <http://lists.rtems.org/pipermail/users/attachments/20150430/07bc7f31/attachment-0002.html>
