Installation query
Fri Aug 7 15:32:56 UTC 2015
On 8/7/2015 9:33 AM, Sarvesh Patkar wrote:
> Hey guys,
> I am a newbie. So, I am having a lot of doubts and issues in understanding while installation. I deleted all that I had installed till yesterday and started over. I executed the following commands.
> mkdir -p development/rtems/src
> cd development/rtems/src
> git clone git://git.rtems.org/rtems-source-builder.git <http://git.rtems.org/rtems-source-builder.git>
> cd rtems-source-builder
> source-builder/sb-check
> cd rtems
> ../source-builder/sb-set-builder --log=l-pc386.txt --prefix=/home/sarvesh/development/rtems/4.11 4.11/rtems-i386
> /home/sarvesh/development/rtems/4.11/bin/i386-rtems4.11-gcc -v
> git clone git://git.rtems.org/rtems.git <http://git.rtems.org/rtems.git>
> cd rtems
> export PATH=/home/sarvesh/development/rtems/4.11/bin:$PATH
> ./bootstrap
> cd ..
> mkdir pc386
> mkdir pc386/install
Your install directory should not be under the build directory.
They should be separate.
> cd pc386
> ../rtems/configure --target=i386-rtems4.11 --enable-rtremsbsp=pc386 --enable-tests=samples --disable-posix --prefix=/home/sarvesh/development/rtems/4.11/pc386/install
You spelled the option incorrectly. It is "--enable-rtemsbsp=pc386"
As a point of reference, I have this (more or less) as my tree structure.
~/rtems-4.11-work
    tools
    bsp-install
    b-pc386
There is no obligation or requirement to do it that way. All BSPs can be
installed into a single directory safely. And it could be the same as the
tools directory.
b-pc386 can be removed after the installation.
> make
> This is what happened at the very end of executing 'make'.
> Rest of it seemed all correct.
> Making all in edison
> make[2]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c/edison'
> make[2]: *** No rule to make target `all'.  Stop.
> make[2]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c/edison'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
> make: *** [all-recursive] Error 1
> I also tried running the next command according to the Quick Start page
> sudo PATH=/home/sarvesh/development/rtems/4.11/bin:${PATH} make install
> This is what followed.
> Making install in tools/build
> make[1]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
> make[2]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
>   /bin/mkdir -p '/home/sarvesh/development/rtems/4.11/pc386/install/bin'
>    /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c '/home/sarvesh/development/rtems/4.11/pc386/install/bin'
>   /usr/bin/install -c install-if-change '/home/sarvesh/development/rtems/4.11/pc386/install/bin'
> make[2]: Nothing to be done for `install-data-am'.
> make[2]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
> make[1]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
> Making install in tools/cpu
> make[1]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
> Making install in generic
> make[2]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
> make[3]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
> make[3]: Nothing to be done for `install-exec-am'.
> make[3]: Nothing to be done for `install-data-am'.
> make[3]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
> make[2]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
> make[2]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
> make[3]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
> make[3]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
> make[2]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
> make[1]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
> Making install in testsuites/tools
> make[1]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
> make[2]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
> make[3]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
>   /usr/bin/install -c difftest '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-difftest'
>   /usr/bin/install -c sorttimes '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-sorttimes'
> make[3]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
> make[2]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
> make[2]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
> make[3]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
> make[3]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
> make[2]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
> make[1]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
> Making install in i386-rtems4.11/c
> make[1]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
> Making install in .
> make[2]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
> make[3]: Entering directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
> make[3]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
> make[2]: Leaving directory `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
> *Making install in edison
> make[2]: *** No rule to make target `install'.  Stop.
> make[1]: *** [install-recursive] Error 1
> make: *** [install-recursive] Error 1
> Can you please help me understand why this may be happening and how it can be overcome?
> Thank you,
> Sarvesh Patkar
