Installation query
Sujay Raj
sujayraaj at gmail.com
Sat Aug 8 06:23:19 UTC 2015
If there aren't any errors or warnings, I believe you are good to try your
hands at the hello or ticker sample.
To simulate i386, you should prefer QEMU.
qemu-system-i386 -kernel <your-executable-file>
you can also try the examples-v2 repository. There are lot of examples
for someone to begin with.
export the RTEMS_MAKEFILE_PATH variable to INSTALL_POINT/i386-rtems4.11/pc386
, where INSTALL_POINT is where you installed your bsp, and then a make
will build the examples.
On Sat, Aug 8, 2015 at 1:42 AM, Sarvesh Patkar <sarveshspatkar at gmail.com>
wrote:
> Thanks for the quick replies. I tried it as you said. I realised the typo.
> How can I be sure of whether it happened correctly now? (I didn't see the
> warnings this time)
> On Fri, Aug 7, 2015 at 1:05 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> On 8/7/2015 11:40 AM, Donald H Locker wrote:
>>> Thank you for this, Joel. Can you please clarify the directory structure?
>>> My understanding is that the non-prefixed directories are sub-dirs of
>>> the first, i.e. the structure is:
>>> ~/rtems-4.11-work
>>> ~/rtems-4.11-work/tools
>>> ~/rtems-4.11-work/bsp-install
>>> ~/rtems-4.11-work/rtems
>>> ~/rtems-4.11-work/b-pc386
>>> Is this a correct interpretation?
>> Yes. But that is just my working environment. It is not the only
>> way to do it. :)
>> The important thing is that the BSP install point be separate from
>> the rtems source or build directories.
>> It may or may not be the same as the tools installation. Personal
>> or project preference.
>> Thank you again,
>>> Donald.
>>> ----- Original Message -----
>>>> From: "Joel Sherrill" <joel.sherrill at oarcorp.com>
>>>> To: "Sarvesh Patkar" <sarveshspatkar at gmail.com>, users at rtems.org
>>>> Sent: Friday, August 7, 2015 11:32:56 AM
>>>> Subject: Re: Installation query
>>>> On 8/7/2015 9:33 AM, Sarvesh Patkar wrote:
>>>>> Hey guys,
>>>>> I am a newbie. So, I am having a lot of doubts and issues in
>>>>> understanding
>>>>> while installation. I deleted all that I had installed till yesterday
>>>>> and
>>>>> started over. I executed the following commands.
>>>>> mkdir -p development/rtems/src
>>>>> cd development/rtems/src
>>>>> git clone git://git.rtems.org/rtems-source-builder.git
>>>>> <http://git.rtems.org/rtems-source-builder.git>
>>>>> cd rtems-source-builder
>>>>> source-builder/sb-check
>>>>> cd rtems
>>>>> ../source-builder/sb-set-builder --log=l-pc386.txt
>>>>> --prefix=/home/sarvesh/development/rtems/4.11 4.11/rtems-i386
>>>>> /home/sarvesh/development/rtems/4.11/bin/i386-rtems4.11-gcc -v
>>>>> git clone git://git.rtems.org/rtems.git <
>>>>> http://git.rtems.org/rtems.git>
>>>>> cd rtems
>>>>> export PATH=/home/sarvesh/development/rtems/4.11/bin:$PATH
>>>>> ./bootstrap
>>>>> cd ..
>>>>> mkdir pc386
>>>>> mkdir pc386/install
>>>> Your install directory should not be under the build directory.
>>>> They should be separate.
>>>> cd pc386
>>>>> ../rtems/configure --target=i386-rtems4.11 --enable-rtremsbsp=pc386
>>>>> --enable-tests=samples --disable-posix
>>>>> --prefix=/home/sarvesh/development/rtems/4.11/pc386/install
>>>> You spelled the option incorrectly. It is "--enable-rtemsbsp=pc386"
>>>> As a point of reference, I have this (more or less) as my tree
>>>> structure.
>>>> ~/rtems-4.11-work
>>>> tools
>>>> bsp-install
>>>> rtems
>>>> b-pc386
>>>> There is no obligation or requirement to do it that way. All BSPs can be
>>>> installed into a single directory safely. And it could be the same as
>>>> the
>>>> tools directory.
>>>> b-pc386 can be removed after the installation.
>>>> make
>>>>> This is what happened at the very end of executing 'make'.
>>>>> Rest of it seemed all correct.
>>>>> Making all in edison
>>>>> make[2]: Entering directory
>>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c/edison'
>>>>> make[2]: *** No rule to make target `all'. Stop.
>>>>> make[2]: Leaving directory
>>>>> make[1]: *** [all-recursive] Error 1
>>>>> make[1]: Leaving directory
>>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
>>>>> make: *** [all-recursive] Error 1
>>>>> I also tried running the next command according to the Quick Start page
>>>>> sudo PATH=/home/sarvesh/development/rtems/4.11/bin:${PATH} make install
>>>>> This is what followed.
>>>>> Making install in tools/build
>>>>> make[1]: Entering directory
>>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
>>>>> /bin/mkdir -p
>>>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin'
>>>>> /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c
>>>>> /bin/mkdir -p
>>>>> /usr/bin/install -c install-if-change
>>>>> make[2]: Nothing to be done for `install-data-am'.
>>>>> Making install in tools/cpu
>>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
>>>>> Making install in generic
>>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
>>>>> make[3]: Entering directory
>>>>> make[3]: Nothing to be done for `install-exec-am'.
>>>>> make[3]: Nothing to be done for `install-data-am'.
>>>>> make[3]: Leaving directory
>>>>> Making install in testsuites/tools
>>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
>>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
>>>>> /bin/mkdir -p
>>>>> /usr/bin/install -c difftest
>>>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-difftest'
>>>>> /usr/bin/install -c sorttimes
>>>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-sorttimes'
>>>>> Making install in i386-rtems4.11/c
>>>>> Making install in .
>>>>> *Making install in edison
>>>>> make[2]: *** No rule to make target `install'. Stop.
>>>>> make[1]: *** [install-recursive] Error 1
>>>>> make: *** [install-recursive] Error 1
>>>>> Can you please help me understand why this may be happening and how it
>>>>> can
>>>>> be overcome?
>>>>> Thank you,
>>>>> Sarvesh Patkar
>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150808/ecb3bb57/attachment-0001.html>
