a question about SD card rtems_blkdev_generic functions
Chan Kim
ckim at etri.re.kr
Wed Aug 19 12:46:27 UTC 2015
Hello, rtems folks,
I managed to write an SD card driver on our platform (it was a month ago but I was doing other things lately) and am
tryng to test file read and write. File read is done anyway and I can print the file contents.
Couple of days ago I saw block write starting initiated by file write operation, but somehow I don't know how to make block write start.
somewhere in the driver, there are lines below.
static const rtems_driver_address_table sd_card_disk_ops = {
.initialization_entry = sd_card_disk_init,
.open_entry = rtems_blkdev_generic_open,
.close_entry = rtems_blkdev_generic_close,
.read_entry = rtems_blkdev_generic_read,
.write_entry = rtems_blkdev_generic_write,
.control_entry = rtems_blkdev_generic_ioctl
sc = rtems_io_register_driver( 0, &sd_card_disk_ops, &major);
but strangely, even when I read a file successfully(using fopen, fgets) and print it, only rtems_blkdev_generic_open and rtems_blkdev_generic_close function are called and rtems_blkdev_generic_read/write.functions are not called.
Is this normal? Can someone direct me to a good document on how this works or explain it to me?
Thanks!
Chan
