Installation query
Sarvesh Patkar
sarveshspatkar at gmail.com
Fri Aug 7 20:12:50 UTC 2015
Thanks for the quick replies. I tried it as you said. I realised the typo.
How can I be sure of whether it happened correctly now? (I didn't see the
warnings this time)
On Fri, Aug 7, 2015 at 1:05 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 8/7/2015 11:40 AM, Donald H Locker wrote:
>> Thank you for this, Joel. Can you please clarify the directory structure?
>> My understanding is that the non-prefixed directories are sub-dirs of the
>> first, i.e. the structure is:
>> ~/rtems-4.11-work
>> ~/rtems-4.11-work/tools
>> ~/rtems-4.11-work/bsp-install
>> ~/rtems-4.11-work/rtems
>> ~/rtems-4.11-work/b-pc386
>> Is this a correct interpretation?
> Yes. But that is just my working environment. It is not the only
> way to do it. :)
> The important thing is that the BSP install point be separate from
> the rtems source or build directories.
> It may or may not be the same as the tools installation. Personal
> or project preference.
> Thank you again,
>> Donald.
>> ----- Original Message -----
>>> From: "Joel Sherrill" <joel.sherrill at oarcorp.com>
>>> To: "Sarvesh Patkar" <sarveshspatkar at gmail.com>, users at rtems.org
>>> Sent: Friday, August 7, 2015 11:32:56 AM
>>> Subject: Re: Installation query
>>> On 8/7/2015 9:33 AM, Sarvesh Patkar wrote:
>>>> Hey guys,
>>>> I am a newbie. So, I am having a lot of doubts and issues in
>>>> understanding
>>>> while installation. I deleted all that I had installed till yesterday
>>>> and
>>>> started over. I executed the following commands.
>>>> mkdir -p development/rtems/src
>>>> cd development/rtems/src
>>>> git clone git://git.rtems.org/rtems-source-builder.git
>>>> <http://git.rtems.org/rtems-source-builder.git>
>>>> cd rtems-source-builder
>>>> source-builder/sb-check
>>>> cd rtems
>>>> ../source-builder/sb-set-builder --log=l-pc386.txt
>>>> --prefix=/home/sarvesh/development/rtems/4.11 4.11/rtems-i386
>>>> /home/sarvesh/development/rtems/4.11/bin/i386-rtems4.11-gcc -v
>>>> git clone git://git.rtems.org/rtems.git <http://git.rtems.org/rtems.git
>>>> cd rtems
>>>> export PATH=/home/sarvesh/development/rtems/4.11/bin:$PATH
>>>> ./bootstrap
>>>> cd ..
>>>> mkdir pc386
>>>> mkdir pc386/install
>>> Your install directory should not be under the build directory.
>>> They should be separate.
>>> cd pc386
>>>> ../rtems/configure --target=i386-rtems4.11 --enable-rtremsbsp=pc386
>>>> --enable-tests=samples --disable-posix
>>>> --prefix=/home/sarvesh/development/rtems/4.11/pc386/install
>>> You spelled the option incorrectly. It is "--enable-rtemsbsp=pc386"
>>> As a point of reference, I have this (more or less) as my tree structure.
>>> ~/rtems-4.11-work
>>> tools
>>> bsp-install
>>> rtems
>>> b-pc386
>>> There is no obligation or requirement to do it that way. All BSPs can be
>>> installed into a single directory safely. And it could be the same as the
>>> tools directory.
>>> b-pc386 can be removed after the installation.
>>> make
>>>> This is what happened at the very end of executing 'make'.
>>>> Rest of it seemed all correct.
>>>> Making all in edison
>>>> make[2]: Entering directory
>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c/edison'
>>>> make[2]: *** No rule to make target `all'. Stop.
>>>> make[2]: Leaving directory
>>>> make[1]: *** [all-recursive] Error 1
>>>> make[1]: Leaving directory
>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/i386-rtems4.11/c'
>>>> make: *** [all-recursive] Error 1
>>>> I also tried running the next command according to the Quick Start page
>>>> sudo PATH=/home/sarvesh/development/rtems/4.11/bin:${PATH} make install
>>>> This is what followed.
>>>> Making install in tools/build
>>>> make[1]: Entering directory
>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/build'
>>>> /bin/mkdir -p
>>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin'
>>>> /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c
>>>> /bin/mkdir -p
>>>> /usr/bin/install -c install-if-change
>>>> make[2]: Nothing to be done for `install-data-am'.
>>>> Making install in tools/cpu
>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu'
>>>> Making install in generic
>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/tools/cpu/generic'
>>>> make[3]: Entering directory
>>>> make[3]: Nothing to be done for `install-exec-am'.
>>>> make[3]: Nothing to be done for `install-data-am'.
>>>> make[3]: Leaving directory
>>>> Making install in testsuites/tools
>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools'
>>>> `/home/sarvesh/development/rtems/src/rtems-source-builder/rtems/pc386/testsuites/tools/generic'
>>>> /bin/mkdir -p
>>>> /usr/bin/install -c difftest
>>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-difftest'
>>>> /usr/bin/install -c sorttimes
>>>> '/home/sarvesh/development/rtems/4.11/pc386/install/bin/./i386-rtems4.11-sorttimes'
>>>> Making install in i386-rtems4.11/c
>>>> Making install in .
>>>> *Making install in edison
>>>> make[2]: *** No rule to make target `install'. Stop.
>>>> make[1]: *** [install-recursive] Error 1
>>>> make: *** [install-recursive] Error 1
>>>> Can you please help me understand why this may be happening and how it
>>>> can
>>>> be overcome?
>>>> Thank you,
>>>> Sarvesh Patkar
>>> Joel Sherrill, Ph.D. Director of Research & Development
>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150807/18bd9c63/attachment-0002.html>
