Monitor thread execution (replacement for waitpid)
Saeed Ehteshamifar salpha.2004 at gmail.com
Fri Aug 14 17:55:34 UTC 2015
Hi,
> There is only a single process so those are not supported at all.
Looking at testsuites/samples/base_sp, I wonder why TA1 terminates by
calling "exit(0)", when "WEXITSTATUS" (and the rest of this family) has not
been implemented.
Is parent able to monitor how child terminated via directives other than
WEXITSTATUS?
Kind Regards,
SAeeD
On Tue, Aug 11, 2015 at 8:06 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 8/11/2015 11:28 AM, Saeed Ehteshamifar wrote:
>> Hi,
>> Because of different process model, RTEMS doesn't support processes.
>> Therefore many POSIX functions (like fork, exec*) are unimplementable on
>> RTEMS.
>> Now my question is how to monitor child thread status (if it is correct
>> to use the term "child" in this context) just like what "waitpid" does?
>> Does it make a difference if the thread has been created via classical API
>> or POSIX?
>> More specifically, I'm interested to directives like WIFEXITED,
>> WEXITSTATUS, WIFSIGNALED, etc.
> If a thread crashes with a memory fault, the CPU will generate a trap
> and the entire program is halted.
>> Kind Regards,
>> SAeeD
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20150814/99e0d714/attachment-0002.html>
