Zynq Ethernet driver
Davide Viti
zinosat at tiscali.it
Thu Dec 10 14:33:34 UTC 2015
Hi Sebastian,
unfortunately I don't have a debugger for the Microzed, and I can reproduce
the problem only on real hardware (I failed to reproduce this both on the
xilinx_zynq_a9_qemu and pc386)
Regarding the ethernet, I managed to get it to work!
The current solution is a quick and dirty hack:
starting from this log snippet (complete log available in[1]):
devctl: ? at phyno=0 oui=0xac2 model=0x1d rev=0x1 on miibus0
my assumption was that no device was found on the miibus (thus the '?').
I looked for the model "0x1d" and noticed that it is not defined in
rtemsbsd/include/rtems/bsd/local/miidevs.h
I changed the following defines from 0xc to 0x1d
#define MII_MODEL_xxMARVELL_E1111 0x001d
#define MII_MODEL_MARVELL_E1111 0x001d
and tried to rebuild both the dhcpd01 and telnetd examples: I managed both
to get an IP address and connect via telnet to the board: both examples had
to be modified to avoid the already discussed crash.
It'd be great to get a proper fix into the repository.
thanx for your help
[1] http://pastebin.com/jJhMH0wN
2015-12-02 18:51 GMT+01:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> Hello Davide,
> I guess you have a general memory corruption problem. If you add the shell
> commands, then you change the memory layout and a visible effect appears or
> not. So this is something for a debugger.
> You have to make sure that the PHY is correctly initialized. For this you
> may have to register a driver. See nexus-devices.h for examples.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-brains.de <http://lists.rtems.org/mailman/listinfo/devel>
URL: <http://lists.rtems.org/pipermail/users/attachments/20151210/68b7d876/attachment.html>
