How to build SMP RTEMS?
Oyake, Amalaye (398F) amalaye.oyake at jpl.nasa.gov
Tue Dec 15 22:08:56 UTC 2015
Hello Dwaine,
I think you could look at the Zynq on a Xilinx board. There may be some
MIPS systems or x86 SBCs.
Which brings up a point that we may want to have a hardware list
(alphabetical + maybe there is one) on the Wiki, with a table of whether
RTEMS has run on it.
Regards
* Amalaye Oyake                                       *
* Instrument Product Software Development Group  */\  *
* Jet Propulsion Laboratory, Pasadena            *||  *
* CA 91109                                       /||\ *
On 12/15/15, 1:58 PM, "users on behalf of Molock, Dwaine S. (GSFC-5820)"
<users-bounces at rtems.org on behalf of dwaine.s.molock at nasa.gov> wrote:
>Is there a list of BSPs and targets that support SMP in RTEMS?
>I'm looking for other multi-core systems other than sparc to possibly buy.
>Thanks
>On Dec 15, 2015, at 11:52 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>On Tue, Dec 15, 2015 at 2:10 AM, Sebastian Huber
>><sebastian.huber at embedded-brains.de> wrote:
>>>On 14/12/15 18:22, Molock, Dwaine S. (GSFC-5820) wrote:
>>>>On Dec 12, 2015, at 3:40 PM, Sebastian Huber
>>>>  wrote:
>>>>>----- Am 12. Dez 2015 um 20:04 schrieb Molock, Dwaine S. (GSFC-5820)
>>>>>dwaine.s.molock at nasa.gov:
>>>>>>Hi,
>>>>>>I'm looking for documentation on how to build the SMP version of
>>>>>>RTEMS?
>>>>>Use --enable-smp for your configure command line.  We have an SMP
>>>>>chapter
>>>>>in the user manual.  Unfortunately, the automatic documentation
>>>>>generation
>>>>>doesn't work currently, so better build the docs from the sources.
>>>>Where can I find instructions on how to manually build the
>>>>documentation
>>>>from source code?
>>>It seems that this is nowhere documented. I use this
>>>cd doc
>>>mkdir b-doc
>>>cd b-doc
>>>../configure --enable-maintainer-mode
>>>make
>>https://git.rtems.org/rtems/tree/doc/README#n26
>_______________________________________________
>users mailing list
>users at rtems.org
>http://lists.rtems.org/mailman/listinfo/users
