git command failed (/usr/bin/git): 128
Sambeet Panigrahi
sambeet161616 at gmail.com
Thu Dec 17 08:17:35 UTC 2015
Hey,
I have been trying to build rtems for the sparc architecture and I keep
getting this error
error: git command failed (/usr/bin/git): 128
i have tried the following
>1. Find rtems/config/tools/rtems-tools-1.cfg
>2. Change lines 23 to 33 to (the following is a single line):
> %source set rtems-tools >https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz <https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz>
>Let me know how that goes.
>Chris
But this again gives the error
error: rtems-tools-git-1.cfg:7: macro '%{rtems_tools_version}' not foundI
I also tried changing the ftp to the https in the
rtems/config/tools/rtems-tools-1.cfg directory ,i.e
https://github.com/RTEMS/rtems-tools.git?reset=hard?branch=%{rtems_tools_version}?pull%{rtems_tools_git_checkout}
%endif
but while cloning rsb still uses the git protocol
git: clone: git://git.rtems.org/rtems-tools.git -> sources/git/rtems-tools.git
which causes the following error
How can we set rsb to use https instead of git protocol? Are there any
other alternatives
to build using rsb using only https? git and ftp both are blocked by my ISP.
URL: <http://lists.rtems.org/pipermail/users/attachments/20151217/9f898f87/attachment.html>
