Fwd: git command failed (/usr/bin/git): 128
Sambeet Panigrahi
sambeet161616 at gmail.com
Thu Dec 17 08:26:52 UTC 2015
> Hey,
> I have been trying to build rtems for the sparc architecture and I keep
> getting this error
> error: git command failed (/usr/bin/git): 128
> i have tried the following
> >1. Find rtems/config/tools/rtems-tools-1.cfg
> >2. Change lines 23 to 33 to (the following is a single line):
> > %source set rtems-tools >https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz <https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz>
> >Let me know how that goes.
> >Chris
> But this again gives the error
> error: rtems-tools-git-1.cfg:7: macro '%{rtems_tools_version}' not foundI
> I also tried changing the ftp to the https in the
> rtems/config/tools/rtems-tools-1.cfg directory ,i.e
> %source set rtems-tools https://github.com/RTEMS/rtems-tools.git?reset=hard?branch=%{rtems_tools_version}?pull%{rtems_tools_git_checkout}
> %endif
> but while cloning rsb still uses the git protocol
> git: clone: git://git.rtems.org/rtems-tools.git -> sources/git/rtems-tools.git
> which causes the following error
> How can we set rsb to use https instead of git protocol? Are there any other alternatives
> to build using rsb using only https? git and ftp both are blocked by my ISP.
URL: <http://lists.rtems.org/pipermail/users/attachments/20151217/e785f015/attachment.html>
