building rtems error
Mon Dec 21 00:10:46 UTC 2015
Ben,
Can you please have a look at this. It would seem your instructions are
effected by the move to 4.12 and this is what the RTEMS tools defaults
to. Maybe using the 4.11 branch would help.
On 20/12/2015 4:45 PM, Hardik Patel wrote:
> Applying steps for building rtems, when i execute command make as per
> Beagleboard xM, Beaglebone black and everything else RTEMS on the
> Beagles
> <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html>
> , i got error . please give me solution. thank you
> image
> Beagleboard xM, Beaglebone black and everything else RTE...
> Beagles Tweet Tue 22 July 2014 Everything about RTEMS on Beagleboards &
> Beaglebones Welcome to...
> View on www.shrike-systems...
> Preview by Yahoo
> Error:
> arm-rtems4.11-gcc -B../../../../../beagleboneblack/lib/ -specs bsp_specs
> -qrtems -mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
> -mcpu=cortex-a8   -o dl01.pre.exe init.o dl-load.o dl-tar.o
> arm-rtems4.11-nm -g -n dl01.pre.exe > dl01.pre.num
> arm-rtems4.11-size dl01.pre.exe
>    text       data        bss        dec        hex    filename
>  183916       1988    264055236    264241140    fbffff4    dl01.pre.exe
> cp dl01.pre.exe dl01.pre.ralf
> rm -f dl01.pre.ralf
> mv dl01.pre.exe dl01.pre
> rtems-syms -e -c "-mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" -o
> dl-sym.o dl01.pre
> : error trying to exec 'arm-rtems4.12-gcc': execvp: No such file or
> directory
> error: compiling wrapper: Compiler error
> make[7]: *** [dl-sym.o] Error 10
> make[7]: Leaving directory
> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/dl01'
> make[6]: *** [all] Error 2
> make[6]: Leaving directory
> make[5]: *** [all-local] Error 1
> make[5]: Leaving directory
> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests'
> make[4]: *** [all] Error 2
> make[4]: Leaving directory
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory
> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c'
> make: *** [all-recursive] Error 1
> hp at hp:~/development/rtems/b-beagle$
> users mailing list
> users at rtems.org
