AW: AW: RTEMS 4.11 Gaisler Uart Driver bytes missing
Hoefle Marco Marco.Hoefle at nanotronic.ch
Tue Dec 22 15:41:10 UTC 2015
Hello,
we got it running using the Gaisler Driver manager.
This was needed before the RTEM config defines:
#include <drvmgr/ambapp_bus.h>
 * Determine if console driver should do be interrupt driven (mode=1)
 * or polling (mode=0).
 /* APBUART0 */
struct drvmgr_key grlib_drv_res_apbuart0[] =
	{"mode", DRVMGR_KT_INT, {(unsigned int)1}},
	/* {"syscon", KEY_TYPE_INT, {(unsigned int)1}}, */
	DRVMGR_KEY_EMPTY
/* LEON3 System with driver configuration for APBUARTs, the
 * the rest of the AMBA device drivers use their defaults.
struct drvmgr_bus_res grlib_drv_resources =
	.next = NULL,
	.resource = {
	{DRIVER_AMBAPP_GAISLER_APBUART_ID, 0, &grlib_drv_res_apbuart0[0]},
	DRVMGR_RES_EMPTY
We can now run a xmodem protocol using 115200 bps.
I hope this helps for others facing the same issue using mainline 4.11 RTEMS.
Marco
________________________________________
Von: Sebastian Huber <sebastian.huber at embedded-brains.de>
Gesendet: Mittwoch, 16. Dezember 2015 13:22
An: Hoefle Marco; users at rtems.org
Betreff: Re: AW: RTEMS 4.11 Gaisler Uart Driver bytes missing
On 16/12/15 12:58, Hoefle Marco wrote:
> Hello Sebastian,
> I guess the driver is in polling mode per default?
Yes, the default is polled. Since you use the driver manager, you have
to change that via the driver manager specific configuration. I don't
know off hand how this works.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
