Booting images with uboot get stuck after execution of rtems
Jan Sommer soja-lists at aries.uberspace.de
Wed Dec 23 13:35:02 UTC 2015
Am Wednesday 16 December 2015, 18:42:08 schrieb Patrick Gauvin:
> I prepare the boot image like this, where "foo.exe" is the RTEMS ELF file:
>     arm-rtems4.11-objcopy -O binary foo.exe foo.bin
>     mkimage -A arm -O rtems -T kernel -C none -a $LOADADDR \
>         -e $ENTRYADDR -n foo -d foo.bin foo.img
> You can find $LOADADDR and $ENTRYADDR using readelf, for me they are
> 0x104000 and 0x104040. I'm using the ZedBoard BSP.
> Then in U-Boot, assuming you have "foo.img" loaded at 0x300000:
>     icache off && dcache off && bootm 0x300000
Ok, I tried again last week, but still no luck so far.
I am not sure if I get the addresses right. In readelf -e I get:
  Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
  Class:                             ELF32
  Data:                              2's complement, little endian
  Version:                           1 (current)
  OS/ABI:                            UNIX - System V
  ABI Version:                       0
  Type:                              EXEC (Executable file)
  Machine:                           ARM
  Version:                           0x1
  Entry point address:               0x8040
  Start of program headers:          52 (bytes into file)
  Start of section headers:          3321920 (bytes into file)
  Flags:                             0x5000202, has entry point, Version5 EABI, soft-float ABI
  Size of this header:               52 (bytes)
  Size of program headers:           32 (bytes)
  Number of program headers:         4
  Size of section headers:           40 (bytes)
  Number of section headers:         33
  Section header string table index: 30
Program Headers:
  Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
  EXIDX          0x01f5c8 0x00102648 0x00102648 0x00008 0x00008 R   0x4
  LOAD           0x0000b4 0x00000000 0x00000000 0x00000 0x01440 RW  0x1
  LOAD           0x0000b8 0x00008000 0x00008000 0x1ceb8 0xf8000 RWE 0x8
  LOAD           0x01cf80 0x00100000 0x00100000 0x02d40 0x7efc000 RW  0x20
Thus I used  LOADADDR = 0x8000 and ENTRYADDR  = 0x8040. Is this correct?
For loading I tried "dhcp ${kernel_addr_r} ticker.img" where kernel_addr_r is 0x01000000.
I also tried to load the image to 0x8000 although I think that might overwrite u-boot.
If I load the raspbian kernel to kernel_addr_r and start it with bootz it runs fine.
I searched the bare bone section of the raspberrypi-forums, but there is not too much discussion regarding u-boot.
I didn't think it would be so complicated to get started with that... :-/
Best regards and happy holidays,
    Jan
> I apologize if this is a little off-topic, but maybe it will be of use to Jan.
> -Patrick
> users mailing list
> users at rtems.org
