git command failed (/usr/bin/git): 128
Sambeet Panigrahi
sambeet161616 at gmail.com
Thu Dec 24 10:29:16 UTC 2015
>If your network connection is blocking ftp or you are having problems
>reaching all the home sites for the package then using the RSB from git
>will not work. The releases use the RTEMS ftp server via https which I
>hope will work for you.
>Please try the 4.11.0-rc1 (release candidate 1) from:
https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/
>The README.txt contains a quick start howto for building using the releases.
Thank You Chris.It worked.
Best Regards
Sambeet
On Sat, Dec 19, 2015 at 12:19 AM, Sambeet Panigrahi <sambeet161616 at gmail.com
> wrote:
> Hey Chris,
> I updated the rsb using git fetch and tried to build again but I still get
> the same error i.e
> error: git command failed (/usr/bin/git): 128.
> Can you please suggest some more alternatives?
> Regards
> Sambeet
> On Thu, Dec 17, 2015 at 1:56 PM, Sambeet Panigrahi <
> sambeet161616 at gmail.com> wrote:
>>> Hey,
>>> I have been trying to build rtems for the sparc architecture and I keep
>>> getting this error
>>> i have tried the following
>>> >1. Find rtems/config/tools/rtems-tools-1.cfg
>>> >2. Change lines 23 to 33 to (the following is a single line):
>>> > %source set rtems-tools >https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz <https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.0-rc1/rtems-tools-4.11.0-rc1.tar.xz>
>>> >Let me know how that goes.
>>> >Chris
>>> But this again gives the error
>>> error: rtems-tools-git-1.cfg:7: macro '%{rtems_tools_version}' not foundI
>>> I also tried changing the ftp to the https in the
>>> rtems/config/tools/rtems-tools-1.cfg directory ,i.e
>>> %source set rtems-tools https://github.com/RTEMS/rtems-tools.git?reset=hard?branch=%{rtems_tools_version}?pull%{rtems_tools_git_checkout}
>>> %endif
>>> but while cloning rsb still uses the git protocol
>>> git: clone: git://git.rtems.org/rtems-tools.git -> sources/git/rtems-tools.git
>>> which causes the following error
>>> How can we set rsb to use https instead of git protocol? Are there any other alternatives
>>> to build using rsb using only https? git and ftp both are blocked by my ISP.
URL: <http://lists.rtems.org/pipermail/users/attachments/20151224/40b45de0/attachment.html>
