building rtems error
Ben Gras beng at shrike-systems.com
Tue Dec 29 12:26:59 UTC 2015
All,
I have changed my RSB recipe (use 4.12 toolchain and newer uboot to
fix build problems), RTEMS mainline (use objcopy 4.12), to all use
4.12 now and everything works again for the BBB and the BBW on
mainline. Unfortunately the bbxm doesn't boot with the newer uboot,
that I still have to investigate/fix.
On Mon, Dec 21, 2015 at 1:10 AM, Chris Johns <chrisj at rtems.org> wrote:
> Ben,
> Can you please have a look at this. It would seem your instructions are
> effected by the move to 4.12 and this is what the RTEMS tools defaults
> to. Maybe using the 4.11 branch would help.
> Chris
> On 20/12/2015 4:45 PM, Hardik Patel wrote:
>> Applying steps for building rtems, when i execute command make as per
>> Beagleboard xM, Beaglebone black and everything else RTEMS on the
>> Beagles
>> <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html>
>> , i got error . please give me solution. thank you
>> image
>> Beagleboard xM, Beaglebone black and everything else RTE...
>> Beagles Tweet Tue 22 July 2014 Everything about RTEMS on Beagleboards &
>> Beaglebones Welcome to...
>> View on www.shrike-systems...
>> Preview by Yahoo
>> Error:
>> arm-rtems4.11-gcc -B../../../../../beagleboneblack/lib/ -specs bsp_specs
>> -qrtems -mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
>> -mcpu=cortex-a8   -o dl01.pre.exe init.o dl-load.o dl-tar.o
>> arm-rtems4.11-nm -g -n dl01.pre.exe > dl01.pre.num
>> arm-rtems4.11-size dl01.pre.exe
>>    text       data        bss        dec        hex    filename
>>  183916       1988    264055236    264241140    fbffff4    dl01.pre.exe
>> cp dl01.pre.exe dl01.pre.ralf
>> rm -f dl01.pre.ralf
>> mv dl01.pre.exe dl01.pre
>> rtems-syms -e -c "-mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" -o
>> dl-sym.o dl01.pre
>> : error trying to exec 'arm-rtems4.12-gcc': execvp: No such file or
>> directory
>> error: compiling wrapper: Compiler error
>> make[7]: *** [dl-sym.o] Error 10
>> make[7]: Leaving directory
>> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/dl01'
>> make[6]: *** [all] Error 2
>> make[6]: Leaving directory
>> make[5]: *** [all-local] Error 1
>> make[5]: Leaving directory
>> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests'
>> make[4]: *** [all] Error 2
>> make[4]: Leaving directory
>> make[3]: *** [all-recursive] Error 1
>> make[3]: Leaving directory
>> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites'
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory
>> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory
>> `/home/hp/development/rtems/b-beagle/arm-rtems4.11/c'
>> make: *** [all-recursive] Error 1
>> hp at hp:~/development/rtems/b-beagle$
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
