How to build SMP RTEMS?
    Sebastian Huber
    Sat Dec 12 20:40:37 UTC 2015
----- Am 12. Dez 2015 um 20:04 schrieb Molock, Dwaine S. (GSFC-5820) dwaine.s.molock at nasa.gov:
> Hi,
> I'm looking for documentation on how to build the SMP version of RTEMS?
Use --enable-smp for your configure command line.  We have an SMP chapter in the user manual.  Unfortunately, the automatic documentation generation doesn't work currently, so better build the docs from the sources.
> Do I need to rebuild just the RTEMS kernel or the tools also?
Only the BSP, which one do you intend to use? SMP is work in progress.
