Booting images with uboot get stuck after execution of rtems
Davide Viti
zinosat at tiscali.it
Wed Dec 16 22:31:53 UTC 2015
Hi Patrick,
would you mind sharing more details on how you prepared the binary image?
I'm using a Avnet Microzed and the only way I managed to execute a program
is
- stripping the ELF first (optional)
- run it via the "bootelf" command in uboot:
u-boot does not enable the "bootelf" as default, so it has to be properly
rebuilt
thank you in advance
Davide
2015-12-16 21:34 GMT+01:00 Patrick Gauvin <pggauvin at gmail.com>:
> This is a bit of a long shot, but when I started using U-Boot with
> RTEMS, I had to run "dcache off" and "icache off" before running the
> bootm command on my ARM platform (Zynq), otherwise it would crash.
> -Patrick
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20151216/eaeb56d0/attachment-0002.html>
