users Digest, Vol 101, Issue 2
orazey2 .
orazey2 at gmail.com
Mon Feb 2 05:11:00 UTC 2015
Please take me off the mail list.
Thanks
On Sun, Feb 1, 2015 at 7:30 PM, <users-request at rtems.org> wrote:
> Send users mailing list submissions to
> users at rtems.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> users-owner at rtems.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of users digest..."
> Today's Topics:
> 1. Re: ARM Getting Started Assistance: Beagleboard, Zedboard, or
> STM32F4Discovery? (Ben Gras)
> 2. Re: ARM Getting Started Assistance: Beagleboard, Zedboard, or
> STM32F4Discovery? (Joel Sherrill)
> 3. Re: ARM Getting Started Assistance: Beagleboard, Zedboard, or
> STM32F4Discovery? (Jonathan Brandmeyer)
> Message: 1
> Date: Mon, 2 Feb 2015 00:40:45 +0100
> From: Ben Gras <beng at shrike-systems.com>
> To: Jonathan Brandmeyer <jonathan.brandmeyer at gmail.com>
> Cc: "users at rtems.org" <users at rtems.org>
> Subject: Re: ARM Getting Started Assistance: Beagleboard, Zedboard, or
> STM32F4Discovery?
> Message-ID:
> CAK+HGR5t+D4hA-GL0sU8uOtAovJuKDrULqzj5dGgZ83ZPWt5Mg at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> Dear all,
> I took a quick look at why the beagle bsp fails to link. It seems
> there is a multilib interaction I don't really understand that is
> causing the symbol to be missing. (The symbol appears in some library
> arch variants and not in others.) I'm not too familiar with how that
> works so I can't find a clean solution right now.
> If possible in your scenario, rebuilding the beagle bsp without the
> multilib option should work as a workaround for now. You can run the
> code on a linaro qemu fork that implements the bbxm if you don't have
> the hw.
> Info on how to do that is at my blog post on the subject,
> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> Let me know if I can help there.
> On Sun, Feb 1, 2015 at 10:56 PM, Jonathan Brandmeyer
> <jonathan.brandmeyer at gmail.com> wrote:
> > I've been doing embedded programming on "proprietary" small RTOS like
> > FreeRTOS, ChibiOS, and DSP/BIOS for about a decade, as well as POSIX
> > programming on Linux systems. I'm interested in using RTEMS as a
> > full-featured POSIX RTOS, to see if it is a portable alternative to
> > the other proprietary RTOS out there. Unfortunately, all of my
> > attempts to get started using the standard documentation have failed
> > miserably. If anyone has successfully gotten any of these BSP's to
> > actually work, it would be very helpful.
> > My host OS is Debian Testing, on x86_64. Source code was checked out
> > of git from the mainline sources on rtems.org.
> > I've successfully built a toolchain using the rtems-source-builder,
> > according to its instructions, with no obvious errors:
> > $ ./source-builder/sb-check
> > $ cd rtems && ../source-builder/sb-set-builder 4.11/rtems-arm.bset
> > --prefix=$HOME/Programs/rtems_4_11 --log=rtems-user-log.txt
> > Recent builds of GCC, the autotools and other standard programs all
> > get successfully installed to my designated --prefix.
> > Next I attempt to build RTEMS for the arm target, and things start to
> fail.
> > $ export PATH=$HOME/Programs/rtems_4_11:$PATH
> > $ cd rtems-git && ./bootstrap && cd ../
> > $ mkdir build_rtems_arm && cd build_rtems_arm
> > $ ../rtems-git/configure --target=arm-rtems4.11
> > --prefix=$HOME/Programs/rtems_4_11 --enable-posix --enable-networking
> > --enable-cxx --enable-tests --enable-multilib
> > --enable-rtemsbsp="stm32f4 beagleboneblack xilinx_zynq_a9_qemu
> > xilinx_zynq_zedboard armcortexa9"
> > $ make -j8 all
> > I've picked the stm32f4 and xilinx BSP's because I actually own those.
> > Well, I own a microzed, but I'm hoping that I can port the zedboard
> > BSP to the microzed without too much difficulty. Failing that, the
> > armcortexa9 target should support some level of generic qemu. I hope.
> > In the "wishlist" category, it would be nice if the recursive
> > Makefiles were written to use the make jobserver for parallel process
> > control. As it stands, the build is almost entirely serial. A little
> > inconvenient, but not fatal.
> > The first thing that goes seriously wrong, is that the beagleboneblack
> > bsp doesn't link. All of its example programs fail to link due to the
> > missing symbol _CPU_Thread_Idle_body.
> > The next thing to go wrong is that some of the test programs (other
> > than examples themselves) on the stm32f4 and xilinx targets fail to
> > build. Each of these Makefiles have a set of steps like this:
> > $(PAX) = # empty assignment
> > sometarget: someprereqs
> > $(PAX) -w -f $@ $<
> > I don't know what program $(PAX) is supposed to be referencing, but
> > since it is an empty variable, the program w(1) gets executed instead.
> > Instead of creating a tar file from a .o file, it describes the
> > current machine load to the console, producing an error sequence like:
> > make[6]: Entering directory
> '/home/jonathan/src/build_rtems_arm/arm-rtems4.11/c/stm32f4/testsuites/libtests/dl01'
> > w -f dl.tar dl-o1.o
> > 21:59:30 up 31 days, 11:10, 3 users, load average: 1.83, 2.49, 2.08
> > USER TTY LOGIN@ IDLE JCPU PCPU WHAT
> > ../../../../../../tools/build/rtems-bin2c -C dl.tar dl-tar.c
> > ../../../../../../tools/build/rtems-bin2c -H dl.tar dl-tar.h
> > cannot open dl.tar for reading
> > Makefile:645: recipe for target 'dl-tar.c' failed
> > make[6]: *** [dl-tar.c] Error 1
> > make[6]: *** Waiting for unfinished jobs....
> > # trimmed: Make continues to unwind its recursive invocations.
> > OK, so I cut out the beaglebone bsp, and reduce the testsuite down to
> > demonstration samples (starting from a fresh build directory):
> > --enable-cxx --enable-tests=samples --enable-multilib
> > --enable-rtemsbsp="stm32f4 xilinx_zynq_a9_qemu xilinx_zynq_zedboard
> > armcortexa9"
> > $ make -j8 all
> > $ make install
> > This build at least completes. However, the sample test programs
> > don't run. Using the armcortexa9 bsp:
> > jonathan at pheonix:~/src/build_rtems_arm$ arm-rtems4.11-gdb
> > ./arm-rtems4.11/c/armcortexa9/testsuites/samples/ticker/ticker.exe
> > GNU gdb (GDB) 7.8.1
> > Copyright (C) 2014 Free Software Foundation, Inc.
> > License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> > This is free software: you are free to change and redistribute it.
> > There is NO WARRANTY, to the extent permitted by law. Type "show
> copying"
> > and "show warranty" for details.
> > This GDB was configured as "--host=x86_64-linux-gnu
> --target=arm-rtems4.11".
> > Type "show configuration" for configuration details.
> > For bug reporting instructions, please see:
> > <http://www.gnu.org/software/gdb/bugs/>.
> > Find the GDB manual and other documentation resources online at:
> > <http://www.gnu.org/software/gdb/documentation/>.
> > For help, type "help".
> > Type "apropos word" to search for commands related to "word"...
> > Reading symbols from
> ./arm-rtems4.11/c/armcortexa9/testsuites/samples/ticker/ticker.exe...done.
> > (gdb) target sim
> > Connected to the simulator.
> > (gdb) load
> > Loading section .start, size 0x1e4 vma 0x0
> > Loading section .text, size 0x14eb0 vma 0x1e4
> > Loading section .init, size 0x18 vma 0x15094
> > Loading section .fini, size 0x18 vma 0x150ac
> > Loading section .rodata, size 0x1150 vma 0x150c4
> > Loading section .ARM.exidx, size 0x8 vma 0x16214
> > Loading section .eh_frame, size 0x48 vma 0x1621c
> > Loading section .init_array, size 0x4 vma 0x16264
> > Loading section .fini_array, size 0x4 vma 0x16268
> > Loading section .jcr, size 0x4 vma 0x1626c
> > Loading section .data, size 0x5c0 vma 0x166b0
> > Start address 0x40
> > Transfer rate: 737664 bits in <1 sec.
> > (gdb) run
> > Starting program:
> /home/jonathan/src/build_rtems_arm/arm-rtems4.11/c/armcortexa9/testsuites/samples/ticker/ticker.exe
> > [Inferior 1 (process 42000) exited with code 0110]
> > (gdb) quit
> > Similar (same?) problem with qemu on the xilinx_zynq_a9_qemu bsp:
> > jonathan at pheonix:~/src/build_rtems_arm$ qemu-system-arm -S -s
> > -no-reboot -serial mon:stdio -serial /dev/null -net none -nographic -M
> > xilinx-zynq-a9 -m 256M -kernel
> ./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/ticker/ticker.exe
> > Warning: nic cadence_gem.0 has no peer
> > Warning: nic cadence_gem.1 has no peer
> > The nic warnings should be harmless since I've specified explicitly
> > disabling the network interface. Nevertheless, QEMU just halts here
> > with no output whatsoever. It must be killed externally. In this
> > case, qemu-system-arm is v2.1+dfsg-11 as packaged by the Debian
> > project. A fresh build of qemu directly from their Git repository has
> > the same result.
> > So yeah. I would appreciate any help in getting these targets to
> > build. I understand that I'm working with the development repository,
> > and some measure of breakage and instability is to be expected. It
> > also seems that my most preferred target (the Zynq) has the steepest
> > hill to climb according to the mailing list archives. But since the
> > BSP's that I want to use are only present in the 4.11 development
> > series, here I am.
> > Sincerely,
> > Jonathan Brandmeyer
> > users mailing list
> > users at rtems.org
> Message: 2
> Date: Sun, 1 Feb 2015 16:53:52 -0700
> From: Joel Sherrill <joel.sherrill at oarcorp.com>
> To: Ben Gras <beng at shrike-systems.com>, Jonathan Brandmeyer
> STM32F4Discovery?
> Message-ID: <10FCCAB7-EEBA-46DD-9716-63610F1218BF at oarcorp.com>
> Content-Type: text/plain; charset="UTF-8"
> On February 1, 2015 4:40:45 PM MST, Ben Gras <beng at shrike-systems.com>
> wrote:
> >Dear all,
> Building multilib is rather useless to most people. It builds the cpukit
> for every arm CPU variant GCC knows. In this case, the error is in a
> variant we don't have a BSP for. You only need one of the variants. More
> below.
> Build rtems for a single BSP and drop the multilib option. For some BSPs,
> you might see an issue linking a dynamic loading test. I saw it on the Pi
> last week but the other test ran.
> >the hw.
> The rtems $prefix/bin should be at the head of your PATH. Especially when
> you bootstrap RTEMS.
> >fail.
> >> $ make -j8 all
> >those.
> >hope.
> >little
> There is a much faster replacement build system being worked on. We are
> trying to wrap up outstanding tickets and branch before switching.
> >beagleboneblack
> >the
> Multilib issue I am sure. I build all bsps fairly regularly and the beagle
> builds without that option.
> >> $(PAX) -w -f $@ $<
> >instead.
> >like:
> >> w -f dl.tar dl-o1.o
> >2.08
> You don't appear to have tar installed. Pax is the FOSS tar
> implementation. If you loom in the logs, there is probably a message about
> what it looked for.
> >> armcortexa9"
> >> $ make -j8 all
> >> $ make install
> >> GNU gdb (GDB) 7.8.1
> ><http://gnu.org/licenses/gpl.html>
> >copying"
> >> (gdb) target sim
> >> (gdb) load
> >> Start address 0x40
> >> (gdb) run
> >> Starting program:
> >> (gdb) quit
> The simulator in gdb does not support all the instructions for all the arm
> models. Not sure if this is the issue but with cortex seems likely from
> memory.
> >-M
> >has
> >> the same result.
> Qemu is an interesting project which doesn't seem to merge patches in a
> timely manner. Very likely unless you use the RSB to build a qemu, you want
> get the needed patches. As Ben mentioned Linaro's qemu works for the
> Beagle. I think the rsb works for realview and zynq. Not sure for beagle.
> >repository,
> >> series, here I am.
> >> Sincerely,
> >> Jonathan Brandmeyer
> >> users mailing list
> >> users at rtems.org
> >users mailing list
> >users at rtems.org
> --joel
> Message: 3
> Date: Sun, 1 Feb 2015 17:30:46 -0700
> From: Jonathan Brandmeyer <jonathan.brandmeyer at gmail.com>
> To: "users at rtems.org" <users at rtems.org>
> STM32F4Discovery?
> Message-ID:
> <CAGe17FtMMO02-Zq6=
> 8LF-ZGhCoGx-8kb7kEcdL0op7XSXP+kdw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> arm models. Not sure if this is the issue but with cortex seems likely from
> memory.
> >>-M
> >>has
> >>> the same result.
> Unfortunately, qemu doesn't build via the RSB. RSB references some
> patches that 404 out right now (log attached).
> $ ../source-builder/sb-set-builder --prefix=$HOME/Programs/rtems_4_11
> devel/qemu.bset
> -Jonathan
> -------------- next part --------------
> RTEMS Tools Project - Source Builder Error Report
> Build: error: downloading
> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch:
> all paths have failed, giving up
> Command Line: ../source-builder/sb-set-builder
> --prefix=/home/jonathan/Programs/rtems_4_11 devel/qemu.bset
> Python: 2.7.8 (default, Oct 18 2014, 12:50:18) [GCC 4.9.1]
> git://
> git.rtems.org/rtems-source-builder/origin/712516ac1eceb988b06ae1df0ab53f7d27bbfd23-modified
> Linux jonathan-laptop-lenovo 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt2-1
> (2014-12-08) x86_64
> Tail of the build log:
> /usr/bin/install -c -m 644 ../../glib-2.39.3/po/Makefile.in.in \
> /home/jonathan/src/rtems-source-builder/rtems/build/tmp/glib-2.39.3-x86_64-linux-gnu-1-root-jonathan/home/jonathan/Programs/rtems_4_11/share/glib-2.0/gettext/po/
> Makefile.in.in; \
> else \
> fi
> make[2]: Leaving directory
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/po'
> Making install in docs
> make[2]: Entering directory
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/docs'
> Making install in reference
> make[3]: Entering directory
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/docs/reference'
> Making install in glib
> make[4]: Entering directory
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/docs/reference/glib'
> make[5]: Entering directory
> make[5]: Nothing to be done for 'install-exec-am'.
> Nothing to install
> /bin/mkdir -p
> '/home/jonathan/src/rtems-source-builder/rtems/build/tmp/glib-2.39.3-x86_64-linux-gnu-1-root-jonathan/home/jonathan/Programs/rtems_4_11/share/man/man1'
> ../../../../glib-2.39.3/docs/reference/glib/glib-gettextize.1
> ../../../../glib-2.39.3/docs/reference/glib/gtester.1
> ../../../../glib-2.39.3/docs/reference/glib/gtester-report.1
> make[5]: Leaving directory
> make[4]: Leaving directory
> Making install in gobject
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/docs/reference/gobject'
> Nothing to install
> /bin/mkdir -p
> ../../../../glib-2.39.3/docs/reference/gobject/glib-mkenums.1
> ../../../../glib-2.39.3/docs/reference/gobject/glib-genmarshal.1
> ../../../../glib-2.39.3/docs/reference/gobject/gobject-query.1
> Making install in gio
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/docs/reference/gio'
> Making install in gdbus-object-manager-example
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/docs/reference/gio/gdbus-object-manager-example'
> make[6]: Nothing to be done for 'install-exec-am'.
> Nothing to install
> make install-data-hook
> make[7]: Entering directory
> rm -rf
> /home/jonathan/src/rtems-source-builder/rtems/build/tmp/glib-2.39.3-x86_64-linux-gnu-1-root-jonathan/home/jonathan/Programs/rtems_4_11/share/gtk-doc/html/gdbus-object-manager-example
> make[7]: Leaving directory
> make[6]: Leaving directory
> Nothing to install
> /bin/mkdir -p
> ../../../../glib-2.39.3/docs/reference/gio/gapplication.1
> ../../../../glib-2.39.3/docs/reference/gio/gio-querymodules.1
> ../../../../glib-2.39.3/docs/reference/gio/glib-compile-schemas.1
> ../../../../glib-2.39.3/docs/reference/gio/glib-compile-resources.1
> ../../../../glib-2.39.3/docs/reference/gio/gsettings.1
> ../../../../glib-2.39.3/docs/reference/gio/gresource.1
> ../../../../glib-2.39.3/docs/reference/gio/gdbus.1
> ../../../../glib-2.39.3/docs/reference/gio/gdbus-codegen.1
> make[5]: Nothing to be done for 'install-data-am'.
> make[3]: Leaving directory
> make[4]: Nothing to be done for 'install-exec-am'.
> make[4]: Nothing to be done for 'install-data-am'.
> Making install in tests
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/tests'
> make install-recursive
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/tests/gobject'
> make install-am
> Making install in refcount
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build/tests/refcount'
> make install-am
> make[1]: Leaving directory
> '/home/jonathan/src/rtems-source-builder/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/build'
> + cd
> ==> %clean:
> + echo ==> %clean:
> copy:
> /home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset
> config: devel/qemu-git-1.cfg
> package: qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1
> script: 1: #!/bin/sh
> script: 2: # ___build_pre in as set up in defaults.py
> script: 3: # Save the original path away.
> script: 4: export SB_ORIG_PATH=${PATH}
> script: 5: # Directories
> script: 6: SB_PREFIX="/home/jonathan/Programs/rtems_4_11"
> script: 7: SB_PREFIX_CLEAN=$(echo "/home/jonathan/Programs/rtems_4_11" |
> /bin/sed -e 's/^\///')
> script: 8:
> SB_SOURCE_DIR="/home/jonathan/src/rtems-source-builder/rtems/sources"
> script: 9:
> SB_BUILD_DIR="/home/jonathan/src/rtems-source-builder/rtems/build/qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1"
> script: 10: # host == build, use build; host != build , host uses host and
> build uses build
> script: 11: SB_HOST_CFLAGS="-O2 -pipe "
> script: 12: SB_HOST_CXXFLAGS="-O2 -pipe "
> script: 13:
> SB_HOST_LDFLAGS="-L/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset/${SB_PREFIX_CLEAN}/lib"
> script: 14: SB_BUILD_CFLAGS="-O2 -pipe
> -I/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset/${SB_PREFIX_CLEAN}/include"
> script: 15: SB_BUILD_CXXFLAGS="-O2 -pipe
> script: 16:
> SB_BUILD_LDFLAGS="-L/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset/${SB_PREFIX_CLEAN}/lib"
> script: 17: SB_CFLAGS="${SB_BUILD_CFLAGS} "
> script: 18: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
> script: 19: SB_ARCH="x86_64"
> script: 20: SB_OS="linux"
> script: 21: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
> script: 22: export SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
> script: 23: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
> script: 24: export SB_CFLAGS SB_CXXFLAGS
> script: 25: # Documentation
> script: 26: SB_DOC_DIR="/home/jonathan/Programs/rtems_4_11/share/doc"
> script: 27: export SB_DOC_DIR
> script: 28: # Packages
> script: 29:
> SB_PACKAGE_NAME="qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1"
> script: 30:
> SB_PACKAGE_BUILDNAME="qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1"
> script: 31: SB_PACKAGE_VERSION="d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed"
> script: 32: SB_PACKAGE_RELEASE="1"
> script: 33: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
> script: 34: # Build directories
> script: 35: export SB_PREFIX
> script: 36:
> script: 37:
> SB_BUILD_ROOT="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1-root-jonathan"
> script: 38:
> SB_BUILD_ROOT_BINDIR="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1-root-jonathan/${SB_PREFIX_CLEAN}/bin"
> script: 39: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
> script: 40:
> SB_BUILD_CXC_DIR="/home/jonathan/src/rtems-source-builder/rtems/build/qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1-cxc"
> script: 41:
> SB_BUILD_CXC_ROOT="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1-jonathan-cxc"
> script: 42:
> SB_BUILD_CXC_ROOT_BINDIR="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1-jonathan-cxc/${SB_PREFIX_CLEAN}/bin"
> script: 43: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR
> script: 44:
> SB_TMPROOT="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset"
> script: 45:
> SB_TMPPREFIX="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset/${SB_PREFIX_CLEAN}"
> script: 46:
> SB_TMPBINDIR="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset/${SB_PREFIX_CLEAN}/bin"
> script: 47: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
> script: 48:
> SB_TMPCXCROOT="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan/devel/qemu.bset"
> script: 49:
> SB_TMPCXCPREFIX="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan-cxc/devel/qemu.bset/${SB_PREFIX_CLEAN}"
> script: 50:
> SB_TMPCXCBINDIR="/home/jonathan/src/rtems-source-builder/rtems/build/tmp/sb-jonathan-cxc/devel/qemu.bset/${SB_PREFIX_CLEAN}/bin"
> script: 51: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
> script: 52: # Extra path support
> script: 53:
> SB_EXTRAPATH="/home/jonathan/src/rtems-source-builder/source-builder"
> script: 54: # The compiler flags
> script: 55:
> script: 56:
> script: 57: export CFLAGS_FOR_TARGET
> script: 58: export CXXFLAGS_FOR_TARGET
> script: 59: # Set up the path. Put the CXC path first.
> script: 60: if test -n "${SB_TMPBINDIR}" ; then
> script: 61: PATH="${SB_TMPBINDIR}:$PATH"
> script: 62: fi
> script: 63: if test -n "${SB_TMPCXCBINDIR}" ; then
> script: 64: PATH="${SB_TMPCXCBINDIR}:$PATH"
> script: 65: fi
> script: 66: if test -n "${SB_EXTRAPATH}" ; then
> script: 67: PATH="${SB_EXTRAPATH}:$PATH"
> script: 68: fi
> script: 69:
> script: 70:
> script: 71: export PATH
> script: 72: # Default environment set up.
> script: 73: LANG=C
> script: 74: export LANG
> script: 75: unset DISPLAY || :
> script: 76: umask 022
> script: 77: cd
> script: 78: echo "=>
> qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1:"
> script: 79: echo "==> %prep:"
> script: 80: build_top=$(pwd)
> script: 81: source_dir_qemu="qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed"
> source setup:
> qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1: source
> qemu -q -n qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed
> making dir: /home/jonathan/src/rtems-source-builder/rtems/sources/git
> git: clone: git://git.qemu-project.org/qemu.git -> sources/git/qemu.git
> git: pull: git://git.qemu-project.org/qemu.git
> git: checkout: git://git.qemu-project.org/qemu.git =>
> git: submodule: git://git.qemu-project.org/qemu.git <= dtc
> script: 82: cd
> script: 83: /bin/rm -rf qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed
> script: 84: ln -s
> /home/jonathan/src/rtems-source-builder/rtems/sources/git/qemu.git
> ${source_dir_qemu}
> script: 85: cd qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed
> script: 86: /bin/chmod -R a+rX,g-w,o-w .
> making dir: /home/jonathan/src/rtems-source-builder/rtems/patches
> download: http://patchwork.ozlabs.org/patch/406903/raw ->
> patches/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
> checksums:
> Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch:
> 0b1f163808efd1e86ab858053d5df71d => 0b1f163808efd1e86ab858053d5df71d
> script: 87: /bin/cat
> /home/jonathan/src/rtems-source-builder/rtems/patches/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
> | /usr/bin/patch -p1
> download:
> -> patches/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
> download:
> error: HTTP Error 404: Not Found
> error: downloading
> Subject: Digest Footer
> users mailing list
> users at rtems.org
> End of users Digest, Vol 101, Issue 2
URL: <http://lists.rtems.org/pipermail/users/attachments/20150202/4d18d231/attachment-0001.html>
