ARM Getting Started Assistance: Beagleboard, Zedboard, or STM32F4Discovery?
    Jonathan Brandmeyer
    jonathan.brandmeyer at gmail.com
    Mon Feb  2 16:11:32 UTC 2015
Aha, the rosetta stone.  I couldn't figure out how to release the CPU,
since typing 'c' to continue at the console does nothing.  Maybe it is
really waiting for GDB's 'continue' command instead of 'c' at the
monitor console.  At any rate, the core problem is that in this BSP it
is serial1, not serial0 which is directed to the RTEMS console.  I
don't know if that is standard or not.  These documentation changes
describe how I got the example programs to work on the
xilinx_zynq_a9_qemu BSP.
-Jonathan
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/README
b/c/src/lib/libbsp/arm/xilinx-zynq/README
index 6bad853..d9b8657 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/README
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/README
@@ -10,4 +10,15 @@ make
 make install
 export PATH="$PATH:/opt/qemu/bin"
-qemu-system-arm -S -s -no-reboot -serial mon:stdio -serial /dev/null
-net none -nographic -M xilinx-zynq-a9 -m 256M -kernel ticker.exe
+Additionally, qemu-system-arm in Debian 8.0 "Jessie", version 2.1.2 (Debian
+1:2.1+dfsg-11) executes successfully.
+This BSP directs the RTEMS stdio streams to QEMU serial1, not serial0.
+For machine verification with GDB, directing RTEMS stdio to host /dev/null:
+$ qemu-system-arm -S -s -no-reboot -serial mon:stdio -serial
/dev/null -net none -nographic -M xilinx-zynq-a9 -m 256M -kernel
ticker.exe
+For interactive verification from the host console, directing RTEMS stdio to
+the host's shell's stdio:
+$ qemu-system-arm -no-reboot -serial mon:stdio -serial stdio -net
On Sun, Feb 1, 2015 at 11:32 PM, Sebastian Huber
> On 01/02/15 22:56, Jonathan Brandmeyer wrote:
>> Similar (same?) problem with qemu on the xilinx_zynq_a9_qemu bsp:
>> jonathan at pheonix:~/src/build_rtems_arm$ qemu-system-arm -S -s
>> -no-reboot -serial mon:stdio -serial /dev/null -net none -nographic -M
>> ./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/ticker/ticker.exe
>> Warning: nic cadence_gem.0 has no peer
>> Warning: nic cadence_gem.1 has no peer
> Please have a look at the -s and -S options in the Qemu documentation.
> users mailing list
> users at rtems.org
