Run rtems4.11 map xilinx_zynq_zedboard
Nicanord Mukendi Kabobo
nickanord_kbobo at hotmail.com
Thu Feb 12 13:35:02 UTC 2015
Hello,I am a student in France and I want to run rtems4.11 map xilinx_zynq_zedboard. I 've already compiled and install arm-rtems on my pc and I have also installed Vivado 2014 on my fedora 21 64bit os. but I have the dificulties compile u-boot-XLNX.Here are the commands that I have typed:$ cd boot/u-boot-xlnx/$ source /opt/Xilinx/Vivado/2014.4/settings64.sh$ export ARCH=arm$ export CROSS_COMPILE=arm-xilinx-eabi-$ make zynq_zed_configNext I attempt todo make, and things start to fail.$ makescripts/kconfig/conf --silentoldconfig Kconfigscripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h GEN include/autoconf.mkgcc: erreur: unrecognized command line option ‘-mno-unaligned-access’gcc: erreur: unrecognized command line option ‘-mfpu=neon’scripts/Makefile.autoconf:64: recipe for target 'include/autoconf.mk' failedmake[2]: *** [include/autoconf.mk] Error 1Makefile:470: recipe for target 'silentoldconfig' failedmake[1]: *** [silentoldconfig] Error 1make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'. Arrêt.
If anyone has successfully gotten this BSP's toactually work, it would be very helpful.Sincerely,Nicanord Kabobo
URL: <http://lists.rtems.org/pipermail/users/attachments/20150212/da38d849/attachment-0001.html>
