Run rtems4.11 map xilinx_zynq_zedboard
Thomas Doerfler (nt)
Thomas.Doerfler at imd-systems.de
Thu Feb 12 14:01:17 UTC 2015
Nicanord,
most likely you would want to direct this to a U-Boot mailing list? Or a
Xilinx forum? The steps you mention are not related to RTEMS I think.
wkr,
Thomas.
Am 12.02.2015 um 14:35 schrieb Nicanord Mukendi Kabobo:
> Hello,
> I am a student in France and I want to run rtems4.11 map
xilinx_zynq_zedboard. I 've already compiled and install arm-rtems on my
pc and I have also installed Vivado 2014 on my fedora 21 64bit os. but I
have the dificulties compile u-boot-XLNX.
> Here are the commands that I have typed:
> $ cd boot/u-boot-xlnx/
> $ source /opt/Xilinx/Vivado/2014.4/settings64.sh
> $ export ARCH=arm
> $ export CROSS_COMPILE=arm-xilinx-eabi-
> $ make zynq_zed_config
> Next I attempt todo make, and things start to fail.
> $ make
> scripts/kconfig/conf --silentoldconfig Kconfig
> CHK include/config.h
> GEN include/autoconf.mk
> gcc: erreur: unrecognized command line option ‘-mno-unaligned-access’
> gcc: erreur: unrecognized command line option ‘-mfpu=neon’
> scripts/Makefile.autoconf:64: recipe for target 'include/autoconf.mk'
failed
> make[2]: *** [include/autoconf.mk] Error 1
> Makefile:470: recipe for target 'silentoldconfig' failed
> make[1]: *** [silentoldconfig] Error 1
> make: *** No rule to make target 'include/config/auto.conf', needed by
'include/config/uboot.release'. Arrêt.
> If anyone has successfully gotten this BSP's toactually work, it would
be very helpful.
> Sincerely,
> Nicanord Kabobo
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150212/1240379b/attachment.html>
