Problem with m68k source builder
Alexander Krutwig alexander.krutwig at embedded-brains.de
Fri Feb 13 14:25:16 UTC 2015
Hello,
I was executing the following command and the following error occured.
How can it be fixed?
Best regards,
Alex
../source-builder/sb-set-builder --log=log.txt --prefix=/opt/rtems-4.11
4.11/rtems-m68k
RTEMS Source Builder - Set Builder, v0.5.0
warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
Build Set: 4.11/rtems-m68k
Build Set: 4.11/rtems-autotools.bset
Build Set: 4.11/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-linux-gnu-1
building: autoconf-2.69-x86_64-linux-gnu-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-linux-gnu-1
building: automake-1.12.6-x86_64-linux-gnu-1
cleaning: autoconf-2.69-x86_64-linux-gnu-1
cleaning: automake-1.12.6-x86_64-linux-gnu-1
Build Set: Time 0:00:04.979223
Build Set: 4.11/rtems-autotools-base.bset
installing: autoconf-2.69-x86_64-linux-gnu-1 -> /opt/rtems-4.11
installing: automake-1.12.6-x86_64-linux-gnu-1 -> /opt/rtems-4.11
Build Set: Time 0:00:05.017618
Build Set: Time 0:00:09.997739
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
building: expat-2.1.0-x86_64-linux-gnu-1
config: tools/rtems-binutils-2.24-1.cfg
package: m68k-rtems4.11-binutils-2.24-x86_64-linux-gnu-1
building: m68k-rtems4.11-binutils-2.24-x86_64-linux-gnu-1
config: tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg
package: m68k-rtems4.11-gcc-4.9.2-newlib-2.2.0-1-x86_64-linux-gnu-1
building: m68k-rtems4.11-gcc-4.9.2-newlib-2.2.0-1-x86_64-linux-gnu-1
config: tools/rtems-gdb-7.8.2-1.cfg
package: m68k-rtems4.11-gdb-7.8.2-x86_64-linux-gnu-1
warning: gdb-7.8.2.tar.xz: no hash found
building: m68k-rtems4.11-gdb-7.8.2-x86_64-linux-gnu-1
config: tools/rtems-tools-4.11-1.cfg
package: rtems-tools-HEAD-1
git: fetch: git://git.rtems.org/rtems-tools.git ->
sources/git/rtems-tools.git
git: reset: git://git.rtems.org/rtems-tools.git
git: checkout: git://git.rtems.org/rtems-tools.git => master
building: rtems-tools-HEAD-1
error: building rtems-tools-HEAD-1
Build FAILED
   See error report: rsb-report-rtems-tools-HEAD-1.txt
Build Set: Time 0:15:32.375849
Build FAILED
Build failed
Traceback (most recent call last):
   File
"/home/ak/git-rtems-source-builder/rtems/sources/git/rtems-tools.git/.waf-1.7.16-9ca17eb492c97b689870b4ff9db75880/waflib/Task.py",
line 123, in process
     ret=self.run()
   File
line 47, in run
     return m1(self)
   File
"/home/ak/git-rtems-source-builder/rtems/sources/git/rtems-tools.git/.waf-1.7.16-9ca17eb492c97b689870b4ff9db75880/waflib/Build.py",
line 460, in run
     return self.generator.exec_task()
   File
line 476, in exec_install_files
     self.generator.bld.do_install(y.abspath(),destfile,self.chmod)
   File
line 517, in do_install
     shutil.copy2(src,tgt)
   File "/usr/lib64/python2.7/shutil.py", line 131, in copy2
     copystat(src, dst)
   File "/usr/lib64/python2.7/shutil.py", line 98, in copystat
     os.utime(dst, (st.st_atime, st.st_mtime))
OSError: [Errno 2] No such file or directory:
'/home/ak/git-rtems-source-builder/rtems/build/tmp/rtems-tools-HEAD-1-root-ak/opt/rtems-4.11/bin/rtems-test'
shell cmd failed: /bin/sh -ex
/home/ak/git-rtems-source-builder/rtems/build/rtems-tools-HEAD-1/doit
embedded brains GmbH
Alexander Krutwig
Dornierstr. 4
D-82178 Puchheim
Germany
email: alexander.krutwig at embedded-brains.de
Phone: +49-89-18 94 741 - 17
Fax:   +49-89-18 94 741 - 09
PGP: Public key available on request.
