building example programs
Wed Feb 18 14:02:40 UTC 2015
Hi Andrew,
The examples located in testsuites are intended to be compiled with
RTEMS and will not work by copying them elsewhere. For compiling an
application, you should have a look at the examples-v2.git repository
[1]. That should have more info about using RTEMS_MAKEFILE_PATH, and
also has a newer approach to compiling applications for RTEMS that
uses the Waf build system. I highly recommend checking out the
waf-based approach to compiling applications as it has some great
features, albeit at a slight learning curve.
Gedare
[1] https://git.rtems.org/examples-v2/
On Tue, Feb 17, 2015 at 8:16 PM, Andrew Harris <andrew.unit at gmail.com> wrote:
> Hello,  I'm trying to figure out how to start a new RTEMS application.  I
> thought I would start by looking at the ticker example.  I copied the ticker
> example but I am not sure how to compile it.  I am not an expert in
> autoconf/automake and could use some assistance on how to get started.  I
> think I figured out how to configure my RTEMS_MAKEFILE_PATH variable, but
> the only two files in the ticker example are Makefile.am and Makefile.in,
> and I don't know what to do next to build it.  Any help would be
> appreciated!
> -andrew
> users mailing list
> users at rtems.org
